Go Back   ClassicOldsmobile.com > Repair & Restoration > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 03-14-2007, 04:00 AM   #1 (permalink)
Huron
Junior Member
Newbee and a question on total timing.
Hello,
I'm talking about a 350 cubic inch engine in a 1971 Cutlass with a mild performance cam ~216 degrees duration @.050" lift ~.480" lift (unknown manufacturer), 4bbl quadrajet, and auto tranny.
What should I shoot for total timing wise with this setup? What do you usually set your base timing at?
Thanks!
Huron
Huron is offline   Reply With Quote
Sponsored Links
To remove this ad, register today!
Old 03-16-2007, 04:21 AM   #2 (permalink)
Jim's rare 80
Senior Member
Hi. Base timing is 10 btdc. I have a mild cam in mine, I run the timing about 13 btdc. Hope this helps, Jim.
Jim's rare 80 is offline   Reply With Quote
Old 03-16-2007, 06:18 PM   #3 (permalink)
Joel n
Junior Member
Joel n's Avatar
i run 16 in my 74 motor. no mods except ignition. no problems yet. full summer if driving
Joel n is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
