Stock carb/intake for '72 Cutlass 350 4bbl
Old August 9th, 2010, 02:05 PM
oldzy's Avatar
I am likely going to be using a stock Quadrajet 4bbl carb + stock intake when I do my 350 restore in the future. However, I want to have specs closer to the '70 350 with the higher compression. I will likely use stock exhaust manifolds as I hate working with Olds headers.
1) What pistons would I need to come close? ie. Speed Pro ZWL2320F? What would my compression likely be? ie. 9:1? 10.25:1?
2) Do I need to change anything carb/intake wise? I might still have my original Quadrajet laying around. I scrapped my orig. intake long ago, and will need to find another.
3) Preferred cam? I would like something more than the stock cam, but not too much more. I want to be able to use my stock A/C if needed. I will also take it to the drag strip a few times a year.
Thx.
oldzy is offline
Old August 9th, 2010, 04:57 PM
cutlassefi's Avatar
What gear and tranny? That will dictate alot of what will or won't make it a good daily driver.
cutlassefi is offline
Old August 9th, 2010, 07:22 PM
oldzy's Avatar
I have a TH350. At present, I have 2.73's, but will be changing to 3.42's.
oldzy is offline
Old August 10th, 2010, 04:49 AM
cutlassefi's Avatar
Then I'd shoot for 9.5:1 or so. A cam in the 215 range @ .050 should work fine. You can always use a Performer intake and just paint it gold. With that combo you'll have good performance and a nice daily driver.
1968CutlassSupreme
February 8th, 2014 07:06 AM
VintageCarDoc
February 7th, 2014 06:42 PM
charlie_hustle
November 24th, 2010 06:08 PM
oldzy
June 30th, 2010 09:53 AM
Gaz Hog
April 22nd, 2010 07:49 AM
Quick Reply: Stock carb/intake for '72 Cutlass 350 4bbl
