Restoration - Underhood Restoration 70 Cutlass - Lansing built
Old May 19th, 2010, 10:14 AM
Del70's Avatar
A few questions - looking for correct restoration info color/gloss level for a few under hood items
W-25 Hood Hinge Assembly and spring - What color/coating was applied?
Radiator cover plate - I see them gloss, see them flat black .. what is correct?
W-25 Hood Pin retaing brackets (attached to radiator core) What is ths the correct color/gloss level?
Radiator Core - what is the correct color/gloss level?
Hood latch - what is the correct color/gloss level?
Hood pop up spring - - what is the correct color/gloss level?
Del70 is offline
Old May 19th, 2010, 04:07 PM
Past Administrator
Oldsguy's Avatar
Moved to another forum for better exposure.
Oldsguy is offline
Old May 19th, 2010, 04:46 PM
jensenracing77's Avatar
all the cars that i have seen that were "so called survivors" did not have any paint on the hood hinges. i have had 3 low miles original paint cars 68 to 72 since 2000 and none of the hinges were painted on them. as for the % of gloss/flat, i am not sure.
jensenracing77 is offline
Old June 4th, 2010, 09:21 AM
Del70's Avatar
1970 Cutlass - Engine Bay - Proper paint colors/Gloss
Still looking for correct restoration info 70 Cutlass - color/gloss level for a few under hood items..thanks in advance
1) W-25 Hood Hinge Assembly and spring - What color/coating was applied?
2) Radiator cover plate - I see them gloss, see them flat black .. what is correct?
3) W-25 Hood Pin retaing brackets (attached to radiator core) What is ths the correct color/gloss level?
4) Radiator Core - what is the correct color/gloss level?
5)Hood latch - what is the correct color/gloss level?
6) Hood pop up spring - - what is the correct color/gloss level?
Del70 is offline
Old June 4th, 2010, 10:07 AM
VikingBlue's Avatar
#2 and #3
gloss and gloss
VikingBlue is offline
Old June 4th, 2010, 10:32 AM
507OLDS's Avatar
The hood hinges actually had a charcoal gray coating with a sparkle to it.It is called parkerizing. Contact Patton Glade about the correct tints & such for the other items.I just discussed this with him a few months back,as I am in the proccess of restoring another 70 W30 to the exact detail.Every part & piece is getting plated,coated or painted correctly.We just finished the rolling frame,& is now back under the body.
507OLDS is offline
Old June 4th, 2010, 10:48 AM
stevengerard's Avatar
I have seen documents that state core support etc is gloss black. Brian is correct with the hinges, if you use a rattle can of "cast" I hear that looks real close - I know auctions mean nothing but at the last Mecum auction I saw a lot of hinges painted aluminum or cast and they looked good. Many were black as well and "looked" fine but it was clear the better detailed cars had the parkerizing look Brian mentions
stevengerard is offline
Old June 5th, 2010, 02:13 AM
Registered
Bluevista's Avatar
"This thread is worthless without documentation."
My '71's core support was semi-gloss/60 degree gloss black, built in Lansing. The original core support I bought was the same. The Inline Tube '70 W-31 is a Lansing car and the core support is semi-gloss. Go to the Inline Tube site and check out the resto, shows and explains all that stuff, very nice car.
http://www.inlinetube.com/
The 100 percent gloss core supports and top plates always look wrong, they were just a little glossy, not much depth to the finish with no metal prep or primer and dipped in a tank of paint.
I changed the oil on a lot of GM cars back then, just can't remember seeing super glossy core supports, but then again it was the 70's.
The best thing to do with hood hinges besides having them treated over again is to sandblast then spray them with a dry clear, cut down the air pressure or hold the spraycan away. Blasting does bring those "sparkles" out in the steel and looks way better than painting them.
Bluevista is offline
Old October 22nd, 2014, 12:18 PM
StickW31's Avatar
Originally Posted by joesw31
1 phospate gray the springs are not coated
2 semi gloss
3 gloss black
4 semi gloss
5 phospate gray
6 phopate gray
perfect Joe!!!
but i think i like the radiator gloss black!!
StickW31 is offline
Old January 9th, 2019, 04:01 PM
Eddie Hansen's Avatar
Original post removed Sorry wrong thread my apologies
Eddie Hansen is offline
Old January 9th, 2019, 06:57 PM
classicmuscle442's Avatar
Here"s picture of original 70 hinges.
classicmuscle442 is offline
Old June 6th, 2019, 06:28 AM
35tac's Avatar
Nicely done and have fun.
Wayne
35tac is offline
Old July 21st, 2020, 07:41 AM
alsmith787's Avatar
64 Olds Cutlass 330 4v
Are All Olds A-body cars these parts colours & sheen I'm putting together a 1964 olds 442 would like to know once & for all the correct hood hinge color the spring & most of all the latch I know you guys are going to laugh but I've used high powered led lighted magnifying glass & I've been able to put my old electron microscope on it & I for the life of me can identify the original colour on the parts which have never been off or touched
alsmith787 is offline
Old July 21st, 2020, 10:13 AM
If you can see color in your electron microscope you need to submit that for a Nobel Prize in Physics.
Fun71 is online now
Old July 21st, 2020, 10:36 AM
72 Olds CS
RetroRanger's Avatar
Greyscale is a color!
RetroRanger is offline
Old July 21st, 2020, 11:42 AM
alsmith787's Avatar
In desperation I took a silver from side of latch thought I could see something anything NG!
Ur right Fun71
costpenn
June 16th, 2015 06:17 AM
Christophe2m6
December 15th, 2014 04:46 PM
BFitz
Paint
July 5th, 2011 06:47 PM
Tom442
May 31st, 2011 10:12 PM
MLK-442
May 8th, 2011 05:07 AM
Quick Reply: Restoration - Underhood Restoration 70 Cutlass - Lansing built
