Edelbrock throttle cable bracket
Hi , Does anyone have a pic of an edelbrock carb with the throttle linkage installed on there olds engine ?
I cant find the correct bracket that will allow the throttle cable and spring to clear the linkage. I dont want to bend and tweak the stock bracket .
Really need a pic of your edelbrock carb on an olds motor. I can not find a bracket online that will let the throttle cable and spring clear the carb linkage. also I have a perfomer manifold on it. I am thinking a pic would really help out . Thank you Thank you !!
