| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
snapping noise in head
There seems to be a consistent snapping noise in my driver side head. I'm assuming there is something wrong with one of the valves. It speeds up and slows down with the rpms. I am gonna take the cover off tomorrow to try to get a look at it, but i figured i would come here first if any of you know exactly whats wrong, so I can be prepared for it.
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
I bleed Oldsmobile
Snapping?? MMMMMMMM.............or maybe a collapsed lifter and a pushrod hitting a rocker arm??
__________________
DIE HARD OLDS GUY......EAT SLEEP LIVE....OLDSMOBILE
#3 (permalink) |
pulled off cover and everything seemed to be pretty tight and well oiled. lifters and push rods were good. could it just be a valve that is not seating right?
#4 (permalink) |
I bleed Oldsmobile
Fire it and see were its coming from....Just dont run it for long,Or try the broomstick trick.....
__________________
#5 (permalink) |
Check all of the bridges. It may be hard to spot, but I will lay odds that you may have one that snapped.
It is best to unbolt them to see, only unbolt when the cam lobes are NOT on lift for that pair of rockers you are removing. Jim |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| noise from th350 trans ? | ls442 | Transmission | 1 | June 9th, 2009 07:54 AM |
| Mystery Noise | Steeb | General Questions | 9 | February 21st, 2009 05:38 PM |
| 425 Valve Noise | Oldsproject | Big Blocks | 3 | November 30th, 2008 08:58 PM |
| Engine struggling noise | Redog | Small Blocks | 3 | March 7th, 2008 03:34 PM |
| 68 delmont brake noise HELP | sully | Brakes/Hydraulic Systems | 4 | March 30th, 2007 12:26 PM |
