Go Back   ClassicOldsmobile.com > Repair & Restoration > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 11-14-2006, 06:50 PM   #1 (permalink)
Redog
Alero Chapter Secretary
Heater Core Woes
So my 85 Delta with the 307 "Y" motor is really confusing the hell out of me here.
I replaced the heater hoses a while back and instead of taking the in hose (water pump to the core) and looping it around under the air cleaner I put it in straight, and the other hose ( out of the core into the control valve) but ever since I did that, there has been leaking from the core area.
Could it be as simple as I have to loop the "in" hose in order to make the heater core work again?
__________________
Me
2000 Alero running 14's
1985 Delta 88 w/1968 350 rocket
2005 Nissan Altima (her's)
Redog is offline   Reply With Quote
Old 11-15-2006, 05:20 AM   #2 (permalink)
texasred
Super Moderator
texasred's Avatar
If you didn't swap the hoses, I'd check to make sure:
1. You didn't crack the "nipples" on the heater core (easy to do...ask me how I know!)
2. The hoses are seated all the way up and the clamps are on straight and above the flare.
C.J.
__________________
Home of the 1971 Cutlass Supreme convertible Super Karate Monkey Death Car.
texasred is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
