| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
Valve Covers That Clear A/C Brackets
Ok, I'm rebuilding a 350 in a 72 Cutlass, that has air, and would like to replace the valve covers, mainly so I don't have to clean the originals! I'm stepping up to an adjustable valve train, would like to have baffled covers, and provisions for a PVC. What are my options here? I'd really like to have some M/T wrinkle paint covers for it, but I have yet to see any. Suggestions?
| Sponsored Links |
#2 (permalink) |
You should be able to get taller valve covers from a performance outfit like Jegs or Summit Racing. They both have catalogues and websites. There is a guy over at Realoldspower.com that has just finished making some custom ones. Check over there, they are very nice.
__________________
Dan '77 Cutlass Supreme '46 2 door |
#3 (permalink) |
Junior Member
Shoot, Summit & Jegs know me by first name! I've seen what's available, just that the AC bracket is so low, not sure what covers will clear. I'll be doing an adjustable valve train, and probably roller rockers, so, not sure if baffels are an option or not. Any clue which covers will work for sure? And thanks for the RealOldsPower tip, I'll check there too...
#4 (permalink) |
Super Moderator
I went through the same thing on my '71 350. Couldn't find any aftermarket valve covers that clear the AC bracket. CompCams Roller-tip Rockers won't clear the baffles in the stock valve covers. Ended up Dremelling out the baffles and using the stock valve covers. Used new grommets and haven't had any blow-by problems yet.
C.J.
__________________
Home of the 1971 Cutlass Supreme convertible Super Karate Monkey Death Car. ![]()
#5 (permalink) |
Junior Member
That's what I was afraid of, and was considering using the roller tips. I've seen ones advertise in Mondello's catalog that supposedly clear, but there those were without baffles, so guess that's the reason! Yeah, might do the same thing, just hack the factory ones. What did you do for a PVC? Leave it in the stock valve cover location? Do you have an aftermarket intake? You tapped it off where?
#6 (permalink) |
Super Moderator
Stock PCV. New gromets both sides. No leaks. Looks stock.
C.J.
__________________
#7 (permalink) |
Junior Member
Cool, think I'll do the same. Either that, or go for some of those Cal Custom chrome jobs without the baffles. They're cheap enough to where if they don't work, I won;t cry over the money spent! Thanks!
#8 (permalink) |
I don't understand why but I used the comp cams roller tip rockers on my 455 and I didn't have to knock out the baffles on my valve covers. I got the covers out of an early 70's engine in a 98 because they had the oldsmobile script on them and I cleaned them and had them chromed. Maybe the baffles are smaller????
__________________
#9 (permalink) |
Junior Member
Maybe you used a think valve cover gasket? I know there are think ones out there to help with clearance issues...
#10 (permalink) |
Now you have got me wondering
. I am going to have to look and see, the engine is on a stand right now so it shouldn't be too hard, if I can remember ![]()
__________________
#11 (permalink) | |
Super Moderator
Quote:
JUST KIDDING! I had clearance issues on only one rocker on one side (I forget which) but Dremelled out both sides. I thought about thicker gaskets, but I was afraid of clearance problems later. Heck...try fitting hem with the baffles in. If they won't clear, get 'em outa there. C.J.
__________________
#12 (permalink) |
Red, I like your answer, you know ther IS no replacement for displacement! But yes, it is better to be safe and really, there isn't that much oil on the top end in my experience to cause problems without the baffles, a good pcv valve and breather does the trick nicely.
__________________
#13 (permalink) |
Well I looked at the engine and found that there were baffles in the covers and I was using the neoprene gaskets which are not extra thick so, ??????? who know.
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1971 oldsmobile 98 lowrider.... 6 grand invested | TECH9TWISTA | Cars For Sale | 1 | 01-30-2007 02:04 PM |
| speedometer | cutlass tom | Cutlass | 1 | 01-10-2007 11:43 PM |
| need help decoding 442 | new 2 me | 442 | 2 | 11-17-2006 05:23 AM |
| Hello-New to group | melsolds69 | Cutlass | 10 | 04-24-2006 06:41 AM |
