ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Engine & Transmission > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old August 20th, 2006, 09:15 PM   #1 (permalink)
1BAD68"S"
Member
1BAD68"S"'s Avatar
ol4b carb recommendations
okay so i scored an edelbrock ol4b intake that had a crack in the usual heat riser area...well its fixed and you cant even tell it was cracked...anyways i just blew up my big block on the dyno and i have to go with plan "b" and redo the small block. my question is what is the recommended 4bbl carb to top this vintage intake with??
1BAD68"S" is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old August 21st, 2006, 11:42 AM   #2 (permalink)
69deltaconvert
Member
Well if the intake is a spred bore I would put a Q-jet 650 cfm on it. I know they look scary and complicated but they work great and have about the best throtle response of any carb out there. If its a square bore go edelbrock or Carter AFB. If it has an exhaust crossover get the plugs for it from summit.
69deltaconvert is offline   Reply With Quote
Old August 24th, 2006, 03:50 PM   #3 (permalink)
1BAD68"S"
Member
1BAD68"S"'s Avatar
quadrajunk...
im staying away from quadrajunks...i hate them...i wanna say its a sqarebore and im looking at throwing a 750 double pump holly or a 750 squareflange edelbrock on it...not sure...as far as that exaust crossover(heat riser)...thats where the ol4b intakes like to crack and i had mine professionaly done and you cant even tell it was cracked...i mean if they can trust my step dad to weld things for f-22 raptors and the space shuttle then i guess trusting him with my 30 year old vintage intake was a no brainer...oh well...back to wrenchin on the hot rod thanks fer da advice.
Old August 24th, 2006, 08:41 PM   #4 (permalink)
69deltaconvert
Member
Dont forget the crossover block outs they rattle a little bit but they save the manifold and you dont have to weld up the crossover in the heads.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Drum brake hard parts mitsudave Brakes/Hydraulic Systems 5 January 28th, 2007 01:25 PM
rear-end help. Joel n Eighty-Eight 3 December 3rd, 2006 10:48 AM
adjusting the headlights on Alero ventport Alero 6 November 5th, 2006 05:17 PM
455 grunt hunt Fishydoo Big Blocks 6 October 4th, 2006 02:47 PM
Need a stock rim SMOKEYMTNKUSTOMS Parts Wanted 1 April 21st, 2006 05:45 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
