67-330 camshaft specs
Old March 20th, 2017, 11:11 AM
brianbeez67's Avatar
I have a 67-330 (4brl- 320 horsepwr). I looked at the oldsmobillity website and they show the camshaft specs @ .401/.401 lift does any one know the duration of the stock camshafts? thanks brian
brianbeez67 is offline
Old March 21st, 2017, 07:05 AM
I don't know where they got those numbers. This chart is from the 1967 Chassis Service Manual. The CSM shows 0.430/0.432 lift and 278/282 duration. Note that the duration numbers are at first motion (approx 0.005" lift) as opposed to the more commonly accepted 0.050" lift.
joe_padavano is online now
Old March 30th, 2017, 03:40 AM
thanks Joe that helps alot
Old March 30th, 2017, 07:10 AM
Kennybill's Avatar
I have/had four 1967 425 4 barrel engines. All were 39° camshaft angle. Looking at that chart I would "guess" the 4 barrel 330 engines are also 39°. Never "assume" anything, check your angle before buying a camshaft but if it's 39° selection and cost is better. Jmo.
Kennybill is offline
Old March 30th, 2017, 07:24 AM
There's really nothing in that chart that lets you deduce lifter bank angle. The valve event timing information is for one cylinder only.
Old March 30th, 2017, 07:40 AM
Kennybill's Avatar
Looking at the cam identification pictures, I wouldn't think Oldsmobile bean counters would let them make both 45° & 39° camshaft of the same specifications. I've never checked a 1967 330 4 barrel engine but I'm sure someone on the forum has. Jmo
bwichman
June 17th, 2020 10:51 AM
Jakespeed63
September 20th, 2014 08:57 AM
jpaulwhite
May 14th, 2012 04:46 PM
jrblanke
August 7th, 2011 08:19 AM
johnfharding
February 8th, 2009 07:52 PM
Quick Reply: 67-330 camshaft specs
