Olds 350 rebuild price
Old March 13th, 2017, 09:40 PM
RocketRonnie's Avatar
How much was it for you to rebuild your olds 350?
Any tips.
Does anyone know how wide the olds 350 is?
Any aftermarket intakes, headers available?
RocketRonnie is offline
Old March 13th, 2017, 09:46 PM
Edelbrock makes a variety of intake manifolds and there are many companies that offer headers - Hooker, Heddman, etc.
Intake manifolds:
https://www.summitracing.com/search/...-size/5-7l-350
Headers:
https://www.summitracing.com/search/.../oldsmobile-v8
Fun71 is offline
Old March 14th, 2017, 05:42 PM
Thanks for that answer and the links, I should of just asked summit lol.. Do you know how wide the 350 is? Up top?
Old March 14th, 2017, 06:22 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I just measured my 350 on the stand, right around 2 feet without the exhaust manifolds on.
olds 307 and 403 is online now
Old March 14th, 2017, 08:15 PM
Hookers under Hood
76olds's Avatar
[QUOTE=RocketRonnie;999017]How much was it for you to rebuild your olds 350?
Any tips.
I paid $1800.00 for a stock rebuild here in Canada back in 2008. I then added the Edelbrock 2711 intake, Edelbrock 600 CFM carb, hedman shorty headers, Miloden aluminum water pump and a few other things.
I didn't realise at the time, once you do the heads and don't mill them, you will loose compression due to the thicker head gaskets.
I wasn't a member here at the time I had mine rebuilt, if I had been a part of this awesome group of guys, I would have went about things differently and spend more $$$.
Be sure to ask these guys many questions so you can get the build you want.
Here is a picture of my 1976 350 wearing #8 heads.
I hope this helps
Eric
76olds is offline
Old March 14th, 2017, 09:38 PM
Thank you Eric so much.
Olds307/403 was that from cylinder head to cyLinder head?
Old March 15th, 2017, 06:39 AM
Yes, from the outer edge of the center exhaust flange to the other outer edge of the center exhaust flange, the widest part.
Old March 16th, 2017, 05:58 PM
Thanks, much appreciated.
Old March 16th, 2017, 06:05 PM
Chevy budget Olds powered
coppercutlass's Avatar
I spent 3500 +/- but it used alot of swap meet parts / used / and hand me downs.
Runs 12.40's on pump gas.
10 to 1 compression speed pro flat tops (swap meep scores)
lunati voodoo cam 522/539 lift 233/241 duration @ .050 lift
Prw roller rockers 1.6 ford units
Pro gear timing chain
#6 heads done by rocket racing just bowl work 2.07 in. 1.63 ex.
full length headers ,x pipe
34 degrees of timing on 93 octane
edelbrock performer rpm intake
holley 750 cfm double pumper box stock
proform hei dist
Th350 built by me
And yes it really is that plain and basic. Nothing special just got it dialed in pretty good. Most people would spend about 6k on an engine like that i have that in the engine trans and rear end . The key to keeping the price down is doing it all yourself.
coppercutlass is offline
Old March 16th, 2017, 06:44 PM
Thanks coppercutlass because I'm a Swapmeet/junkyard kinda guy. I appreciate those spec numbers!
Old March 16th, 2017, 07:03 PM
Hookers under Hood
76olds's Avatar
Copper, weren't you planning on selling one of you decent 350's soon? It could be a good deal for Ronnie if he's considering a nice build for a decent price.
76olds is offline
Old March 16th, 2017, 07:04 PM
I was selling that combo . But to be honest im not done chipping at that tree trunk. I plan on making the car faster with the same engine lol. I was selling this engine for 2500 but i had no real serious takers. The fact is i was selling this engine at a price you could break even., even if you needed machining but i had no real serious takers so it will continue to be in service until the car is painted and i have money to wrap up the next engine which is 90 percent done.
Old March 16th, 2017, 07:31 PM
What will be your "next engine"
Old March 16th, 2017, 07:32 PM
Ronnie needs another 2,000 hahahahaha
Like most Americans I'm waiting on my income tax check. Lol
Old March 16th, 2017, 07:37 PM
My " next " engine will be another 355 olds built along the same lines but i got some really good hand me downs and its take over 5 years to build. But its 355 with lighter pistons , ported heads , solid lifter cam ,single plane intake , Just a better build all around should be well into the 11's in the 1/4 mile.
Old March 16th, 2017, 10:43 PM
Hookers under Hood
76olds's Avatar
If its anything like Canada, I been waiting for the last 33 years in a row!! Still nothing comes haha.
Jus payin' 'n' payin'
76olds is offline
Old March 17th, 2017, 01:04 PM
thats going to be dope.
76olds - "a dollar a day"
Old March 17th, 2017, 07:25 PM
here it is in action. This summer she will be rocking new paint and lots of new parts.
Old March 17th, 2017, 07:52 PM
jfb
jfb's Avatar
small info about real olds powered post.
proform hei dist
Th350 built by me
this is not a hijack but info if you have not finished the bodywork yet on you ride.vfn parts period. the hoods save 45,fenders save 70 a pair,deck lid saves 30 bumpers save 33 a piece trust me I got these numbers first hand from the manufacturer. stripping your ride clean can save 40 to 60 pds and thinner gauge panels also save weight trying to get on rop can be frustrating so this is the only place for these quotes among us. intakes heads etc in aluminum save more weight and a hundred pounds is about a tenth and a half. porting heads also saves weight. good luck out there and run hard.
jfb is offline
Old March 17th, 2017, 08:06 PM
I prefer glasstek., VFN is junk imo. Car is getting glass hood , deck lid and lexan side glass. I had glasstek fenders and hood in the past. The doors have had the beams taken out and once i go to the lexan i will closer to shaving 45 lbs from each door. I really want to shave about 200 lbs which will put me about in the 12.20 e/t and then try a new converter and hopefully the new fuel pump will help and we can get a 12.0 11.99 from it before the new engine. If money allows im doing glass bumpers too.
Old March 17th, 2017, 08:10 PM
here is a link to the thread on my current doings. https://classicoldsmobile.com/forums...-part-2-a.html
Old March 17th, 2017, 08:51 PM
Niceeee traction. That had to be the best thing I seen all day. Your Olds 350 is taking names and pulling tickets. Props
Old March 18th, 2017, 05:21 AM
Good to know about VFN. I believe you, being a body man by trade. Weight is like free horsepower. I will be happy with high 13's out my car but mine will be a hop in and drive 6 hours away getting 20+ mpg and be fun. The 88 might get this treatment, the Brougham interior in it is heavy and needs to go plus the driver's floor and rear frame need attention.
Old March 18th, 2017, 06:35 AM
jfb
jfb's Avatar
absolutely with that idea.
I cannot agree with you more painted bumpers was a option with rallye 350 packages in the day and putting light weight strong metal beams behind them helps. steel wheels also weigh you down and increase rolling resistance centerlines etc in aluminum save about 80 to 90 pounds also and in the right place just keep a list of weight savings it adds uo and then you need less torque to move out and also use a old superstock trick on the front end limiters. bill grumpy Jenkins came up with the idea for weight transfer otherwise go for the sleeper look. I would also suggest you use a lot more shims at the bottoms of the fenders and paint or rust proof them for proper alignment to the door and rocker the main point for the fenders is mid fender to cowl it makes a huge difference. good luck I know time is crucial.
jfb is offline
Old March 18th, 2017, 10:14 AM
rlorman's Avatar
Cost depends on what you want to do. I got close to $4000 in mine still need headers and exhaust. Edelbrock performer rpm heads, Scorpion rockers, Comp cam and lifters, Liberty timing set, Edelbrock performer intake, Quick Fuel 650 carb, Carter P4600hp fuel pump, Champion aluminum radiator, and of course all the new tune up parts and water pump and other miscellaneous items.
rlorman is offline
Old March 18th, 2017, 10:33 AM
Yeah i dont have the cleanest set up but it works lol.
Old March 18th, 2017, 03:30 PM
jfb
jfb's Avatar
Exclamation nice detailing.
Originally Posted by rlorman
Cost depends on what you want to do. I got close to $4000 in mine still need headers and exhaust. Edelbrock performer rpm heads, Scorpion rockers, Comp cam and lifters, Liberty timing set, Edelbrock performer intake, Quick Fuel 650 carb, Carter P4600hp fuel pump, Champion aluminum radiator, and of course all the new tune up parts and water pump and other miscellaneous items. I like a detailed engine compartment .with good thought process the upkeep is really minimal guys usually just valve covers and timing cover plus air conditioner and alternator for me everything else is aluminum and stainless. I pop the hood after a good run for cooling and most do not believe something pretty can run well but that is my angle to shiny to be taken seriously with class.
jfb is offline
Old March 18th, 2017, 03:35 PM
jfb
jfb's Avatar
guys here is 1 more thing I do not have a way of uploading pictures. I will notice you at the track and I am sure we will meet somewhere Byron 66 the grove or maybe 41.
jfb is offline
Old March 18th, 2017, 04:00 PM
Byron is my home track and its 60 mile drive directly west from my house so thats my usual spot but my good friend 67cutlassfreak is 10 min. from the grove and can usually get me in for near nothing ., also a 60 mile drive but its a long winded drive compared to the straight shot.
Old March 19th, 2017, 06:32 AM
  #31
jfb
jfb's Avatar
i have a overdrive and you can get them used even old units from motion performance days. motion was a major player for chevy in the sixties just like nicky and yenko and also harrell out of Kansas city. hone o dives are around periodically but used gvod are more common .I can go on for days about things like this and that's the reason I like these cars history and function. I periodically run a lot more power and if a issue should rise unexpedectly it is good to be closer to home to control costs it can happen. I built my ride with heavy duty parts period so I have a extra once of protection but with looks and perforamce and looking factory stock and new.
jfb is offline
Old March 19th, 2017, 07:29 AM
  #32
Jtb - you hijacking this thread is very helpful for me, that's how I learn, from others. Your post are appreciated. Thanks alot, I love going the local drag strip.
Ronnie
Old March 19th, 2017, 07:38 AM
  #33
rlorman - impressive engine bay. I never was one for the shine but you shut me up for sure, you found a way to pull it off.
Jtb- if your having probs with the pics then you should do a post in "site related" in the forum.
Copercutlass - thats how I like my set up, classicly muscle-ishis.
geeves
November 14th, 2015 10:36 PM
pfergy600
October 18th, 2013 07:21 PM
fly1
February 17th, 2011 04:17 PM
442oldslawyer
April 29th, 2010 09:22 PM
olds88royalvert
October 23rd, 2009 05:42 AM
Quick Reply: Olds 350 rebuild price
