ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Engine & Transmission > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Dealer Listings
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old July 30th, 2006, 05:11 PM   #1 (permalink)
glb1948
Junior Member
Cam question
Here are the vitals. I have a 87 Olds Cutlas with a 72 350 Old Rocket. There is a Comp Cams 268/268,456/456. It has an edelbrock performer rpm intake with an edelbrock 750 carb. All MSD ignition. A TH400 with shfit kit with a 2000-2200 stall convertor and a 9" ford rear with 4:11 gears. I want to use the car for street/strip. My questions is this. On hard acceleration the car will bog slighlty then run super but the valves seem to be floating around 4200 rpms. Does anybody have a suggestion for a good stout cam with a nice lope to it? Any infor is apprectiated...Thanks, Gary
glb1948 is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old July 31st, 2006, 07:54 AM   #2 (permalink)
Oldsguy
Hot Rodder at heart Administrator
Oldsguy's Avatar
Going to a stouter cam will not fix your problems with bogging and valve float. They may be caused by two seperate issues. Does your bog happen at the start of the hard acceleration? If so, I would look to getting that carb fine tuned, your accelerator pump might be a little too much, or your timing could be off, are you using an MSD ignition box or just the distributor? If you are using the box then it might be able to fix you ignition problem with some adjustments. If the bog comes later in the acceleration it might be related to the valve train and your valve float problem, especially if your heads are all stock. 4200 rpm isn't too much for a small block Olds and you should look into upgrading your heads and valve train. It sounds like you have a pretty good engine/drivetrain build and you just need to massage it some.
__________________
Dan
'77 Cutlass Supreme
'46 2 door
"The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB.
Oldsguy is offline   Reply With Quote
Old July 31st, 2006, 08:31 AM   #3 (permalink)
glb1948
Junior Member
Dan - Thanks for the reply. Yes, I believe the heads are pretty much stock and I was thinking on going to 455 heads. The bog does come right on acceleration but when it does grab, hang on. It does not seem to bad when I manually shift though. I do have the MSD box with a timing control also but the dist I believe is a HEI with a MSD cap on it. I was also told that maybe a 3,000 to 3,500 stall convertor may help to.
Old August 23rd, 2006, 09:10 AM   #4 (permalink)
HWYSTR455
Junior Member
The Edelbrock carbs are known for a transition stumble, and doubt you'll be able to get rid of it without replacing it (pick a Holley Avenger 670 or 770, or a 3311 750 Holley). As for the 'float' you mention, it may be the lifters are chinese junk. Comp had an issue with lifters for some time there, and ended up 're-valving' them with a slower relief internally. Aside from that, I would suggest using the 'Johnston' lifters which are now again available. Several manufacturers carry them now. As for the cam, are those 'advertised' numbers you posted? Seems kind of small, especially with those gears. I would suggest a split-lobe design, and shoot for the mid-220s on the intake, and low-to-mid-230s on the exhaust, like the Comp XE268, or XE274. I like the Crane grinds, like the H-284-2, or the H-272-2, which are the comparable grinds to the COMPs (they have a 112 CL, which gives better idle qualities).
HWYSTR455 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Brekes Proportionate Valve mcutlass1969 Cutlass 3 February 1st, 2007 12:59 PM
door strip protectors? ztim Chassis/Body/Frame 1 December 22nd, 2006 02:05 PM
SSII rims HELP 1980oldssherman tank Other 2 November 17th, 2006 08:28 AM
is a 442clone worth more than a standard cutlass restored to original? oldsmoenewbie Cutlass 1 October 28th, 2006 05:46 PM
1985 Cutlass Supreme 307 hesitation Grinder89 Small Blocks 2 September 15th, 2006 09:16 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
