Because We Needed Another Thread on the Spectre CU165 Radiator
Well I ended up deciding to try to use the 2 row aluminum radiator, and I found out that even these 2 row replacements are bigger than the factory 2 row.
So it wont fit in the saddles of the top plate.
I could probably remove the rubber inserts and use smaller ones. But I would have to do it top and bottom. Anyone else see something I'm missing?
Anyone else tried to use to 2 row replacement? If I'm going to have to modify the top plate and saddles, I might as well try and find myself one of the 4 row copper/brass units. At least it'll be durable!
here's an alternative - I have this in my '72 Cutlass and it drops right in
http://www.autocityclassic.com/cheve...inum-radiator/
Stamped and welded construction sets this apart from the rest. Radiator has transmission cooler. 1 1/2" inlet, 1 1/2" outlet. Original style ribbed tank.
This radiator is a direct replacement. It has dual 1 1/8" high flow tubes, 33% more capacity then 3-row 1/2".
Core size: 28 1/4" wide, 18 3/4" tall, 2 1/2" thick
Overall size (widest point): 33 1/2" wide, 18 3/4" tall, 3" thick
I did talk to him.I thought the aluminum 2 row was a drop in radiator for a copper 2 row. His experience is why I chose to try it. I didn't realize the 2 row wasn't going to fit. If I'm going to have to modify everything, I just feel like it's probably worth having the copper and brass unit.
Anyone in the market for a new Spectra CU165 radiator!?
I am with you on the plastic side tanks. They hold up for years but I had one split out of the blue. Radiators for our old junk is far from simple, either plastic/aluminum or all aluminum that tend to leak or are warped or don't fit right. I hope my recored 2 core is enough for the 350 in hot weather.
It won't. Back in the 80s I bent mine open (well, it was mostly hammering) for a 4 row radiator I had borrowed from my brother in law's 68 GTO, then closed them back when I had my original 3 row end tanks fitted with a 4 row core.
I have to swap it out again, because it leaks at the head under the cap. These friggen plastic tanks really are junk, aren't they!?
It's been a few years so I don't remember the exact amount but it was under $250.
I never had any issues with the replacement plastic/aluminum radiators on my newer cars. And the original one on my Jeep survived 14 years of brutal Arizona 110+ summer heat and serious off-road use before it started leaking.
Whoa. My local guy quoted me $429 to re-core it out to a 3 row radiator, re solder the outlets, etc. I just can't. I'll warranty the plastic one and give it a final go. Luckily it's winter time, and the car is just sitting anyway...
But what would I get? The copper one is 1/2 thinner. so the rows are very narrow(part number spectra cu351). so it's either this, or one of the custom jobs like champion. At least these have a lifetime warranty through the parts store(which it seems like I'll be needing).
Interesting. The spectra one's aren't built too well though. I'll take some photo's tomorrow for reference.
https://m.summitracing.com/parts/sum-380457#
If mine doesn't measure up, this will get the nod, very good reviews, one after a couple of years being used. I considered Griffin but there are too many that leak. In the defence of the plastic tanks, mine was 20 years old and had 350,000 km. They just look like *** in classic cars.
Good suggestions. But it's actually that there is a small crack on the top of the tank.
Interesting. It's a bit expensive(I was really hoping to stay at or under $225ish, but I do like that it has a nipple for a water temperature sender and the good reviews. I may have to make my own craddles for it too, like the other reviewer did. Which honestly, at this point, wouldn't be the worst thing ever. Mine are a little rotted, and though I cleaned them up and the paint in drying, the next time around, should this radiator fail or leak, I'll replace the saddles too. I'll just break down and buy the repro ones(or make my own).
coldwar
February 20th, 2014 01:09 AM
navvet
September 25th, 2011 11:51 AM
