head gasket issue 330 heads on 350... ?
Old December 18th, 2016, 05:36 AM
STLCRZY's Avatar
Guys can it be that the wrong head gasket is the reason for a water leak on on passenger site between the head and block.
We notice it on the engine stand.
Heads are 4# 330
Block 350 68-70
Kit we use
https://m.summitracing.com/parts/slp-260-1022
STLCRZY is offline
Old December 18th, 2016, 05:55 AM
Gaskets are the same. Did you torque the bolts properly in the correct sequence.
oldcutlass is offline
Old December 18th, 2016, 06:59 AM
STLCRZY's Avatar
Yes
STLCRZY is offline
Old December 18th, 2016, 08:02 AM
lemoldsnut's Avatar
Did you have the heads and block check for straightness? and were you very clean about how you put it together and prepared the surfaces?
They take the same gaskets. Should fit perfectly. 4 heads are in my opinion a great head that is way overlooked when it comes to Olds Small blocks.
lemoldsnut is offline
Old December 18th, 2016, 08:14 AM
STLCRZY's Avatar
Problem solved.
STLCRZY is offline
Old December 18th, 2016, 09:42 AM
Originally Posted by STLCRZY
Problem solved.
Care to elaborate?
joe_padavano is offline
Old December 18th, 2016, 10:29 AM
care to elaborate?
x2
Old December 31st, 2016, 09:39 AM
STLCRZY's Avatar
Not property torqued bolts - dead torque wrench
thanks guys
STLCRZY is offline
Old December 31st, 2016, 02:36 PM
Glad all worked out.
Rilmar
July 20th, 2021 08:10 AM
85Cutty442
January 28th, 2016 11:53 AM
ihengineer76
May 10th, 2013 10:01 AM
aussiemobile
February 15th, 2013 07:31 AM
a64olz
July 3rd, 2012 06:32 AM
Quick Reply: head gasket issue 330 heads on 350... ?
