New 350 piston
Old December 11th, 2016, 05:30 AM
cutlassefi's Avatar
New 350 piston
I am pleased to announce that I have received a verbal commitment on a new Forged 350 piston. Although not carved in stone the specs would be;
4.100" bore
4032 material
.980 pin
1.620 compression distance
8cc D shaped Cup and the most modern ring pack available today, 1.00mm, 1.00mm, 2.00mm all steel ring set.
Price would be in the $600.00 range which would include pistons, pins, clips AND rings. Overall piston weight would be significantly less than all the current pistons available today.
This piston will also fit the 400E as well.
cutlassefi is offline
Old December 11th, 2016, 05:40 AM
svnt442's Avatar
Mark I sent you a PM a couple of days ago on another subject. Have you had a chance to read it?
svnt442 is offline
Old December 11th, 2016, 05:45 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Nice Mark, looks like those will give mid to high 9 to 1 compression on a 350 with early heads. That is a fair price with rings and pins, is that the stock pin size? Too bad the Procomp SBO rods were a limited run and measured all over the place.
olds 307 and 403 is offline
Old December 11th, 2016, 05:58 AM
cutlassefi's Avatar
Actually closer to 9.25:1 with a 68cc head and .020 in the hole.
I revised the post to reflect pin size.
Old December 11th, 2016, 06:01 AM
cutlassefi's Avatar
Just did, sorry it was late. Been at the PRI.
Old December 11th, 2016, 08:51 AM
Chevy budget Olds powered
coppercutlass's Avatar
Very nice
coppercutlass is offline
Old December 11th, 2016, 10:25 AM
Thumbs up
I figured .010" in the hole, either way awesome
Old December 11th, 2016, 01:40 PM
" Hoo yah "
815Cutlass1972's Avatar
Nice!
815Cutlass1972 is offline
Old December 11th, 2016, 02:56 PM
Hookers under Hood
76olds's Avatar
I really appreciate you taking the time to bring some nice 350 parts to all of us. I read a statement your wrote in another thread saying " You try your best" . I'm sure everyone here knows that.
The extra time you spend trying to get small bock olds parts produced for us SBO guys really shows your commitment to our community.
Thanks for going above and beyond "just trying",,,, also for all your terrific Olds engine builds, the effort put in to help us all here.
Cheers Mark!!!
Put-r-ther,
Eric
76olds is offline
Old December 16th, 2016, 11:12 AM
Car Nerd
OldSoldier's Avatar
The pin size hurts my ability to consider this piston. Can you explain the reasoning behind the 0.980? Using Oldsmobile rods is probably not going to cut it for my application.
OldSoldier is offline
Old December 17th, 2016, 05:51 AM
cutlassefi's Avatar
Then you'll need to go the Chevy rod and piston route. Or you can buy a bushed Chevy Rod and remove the bushing. That'll get you close to the .980 pin size.
This piston will be an upgrade from the speed pro stuff as well as being an additional size for the 350 and 400E.
shamusj
Brakes/Hydraulic Systems
November 17th, 2023 03:47 PM
MrLightning
June 5th, 2011 06:39 PM
jag1886
February 12th, 2011 11:02 AM
thorpedo91
December 11th, 2008 05:55 PM
topdown
March 2nd, 2007 06:06 PM
Quick Reply: New 350 piston
