What is this line?
Old December 10th, 2016, 03:37 PM
Gmguy6872's Avatar
What is this line?
Need help identifying this line.
Comes off radiator and connects to heating element.
Gmguy6872 is offline
Old December 10th, 2016, 04:01 PM
Look again. I bet it doesn't come from the radiator but instead from the A/C condenser in front of the radiator. That would make it a freon line for the A/C.
joe_padavano is offline
Old December 10th, 2016, 04:32 PM
Gmguy6872's Avatar
Touché! I'm thinking your right.
Old December 10th, 2016, 04:48 PM
Yes, it's broken right off of the expansion valve, with the expansion valve appearing intact.
The end of the line can be replaced, or a whole new line can be purchased (which is probably a better idea and may end up costing the same).
If the A/C's broken anyway (which I would expect, or there would have been quite a cool blast of refrigerant when it broke), you can just wire it up out of the way until you recondition the system.
MDchanic is offline
Old December 10th, 2016, 05:40 PM
Gmguy6872's Avatar
Would this cause me to have no heat? Probably a dumb question as I already know that it's a no... But I can't seem to figure out why I don't have heat?
Old December 10th, 2016, 06:15 PM
Is the hot water valve on the right rear of the intake manifold connected and operating?
MDchanic is offline
70 ctls
March 17th, 2015 09:18 AM
Del70
November 15th, 2013 02:24 PM
davepnola
December 2nd, 2010 09:00 PM
Flye
July 31st, 2009 04:03 PM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: What is this line?
