307 computer qjet with megasquirt
The bigger question is, why bother? All you can control on the CCC system is primary mixture and spark timing (along with the on/off functions like converter lockup, evap canister purge, EGR valve solenoid, etc). It would be much easier to just burn a different PROM for the stock ECU, or use an emulator for real-time control, but frankly, the amount of change you can affect in the primary mixture control is minuscule considering the trouble to swap to an MS computer.
Thanks for the reply Joe. All I am wanting to do is to control primary mixture and timing but the lockup control would be nice as well. I would like to put this on an older non computer Olds 350. For the 02 I was planning on using a wideband for tuning anyway. I just figured that having an ecm to tune with would be nicer than tearing into the carb to adjust the apt and the electronic control of ignition sounds good too. Perhaps what I am looking to do isn't possible. I agree that the megasquirt, even the ms1 computer is overkill for what I want to do but the factory ecm seems like it would not be as user friendly to me as I don't have an egr or evap system.
Thanks Joe. I was thinking I could get something similar to the old Holley dial a mile set up. But if I am not going to be able to get much adjustability from the carb, then all I will have is an expensive convoluted timing control device. I have looked at the tbi set up and it looks like the way to go. Looks like I will have to do some more research.
I really appreciate the input and help on the subject.
You could do what we are doing. We are using a MegaSquirt to control a 454 TBI which is a 2 inch bore and 670 cfm TBI. The injectors are 80 pounders. You can get adapter plates on ebay easy, just make sure you get the right one. The standard TBI's are smaller diameter than the 454's. You can get a TBI in tank fuel pump and pretty much be set.
