Just bought a sweet 215
Old February 16th, 2017, 07:59 PM
  #81
Out of Line, Everytime😉
olds 307 and 403's Avatar
I like those wheels. Very cool build.
olds 307 and 403 is online now
Old February 17th, 2017, 11:20 AM
  #82
young olds's Avatar
Thanks, they are supposed to be bronze but they need a ton of light to show it
young olds is offline
Old February 25th, 2017, 10:34 PM
  #83
young olds's Avatar
Finally brought the engine home from storage. Still needs some work but I'm hoping to start dropping it in in the next few weekends.
Old February 28th, 2017, 05:24 PM
  #84
RoseCityOldsmobile's Avatar
Originally Posted by marxjunk
i know where theres a rust free 63 f85 post car for your racer...its stripped to a shell...and would make a cool racer...cheap...and is really a nice shell..its in Colorado...i just cant buy anything else..til i get some stuff taken care of around the house...i still havent unpacked and ive been here a year and a half....or i would have it
i will put you together with the owner if ya want...
Hey! I'm a '63 fan. Where's this shell in Colorado? I would very much like to speak with the owner. Please and Thank You.
RoseCityOldsmobile is offline
Old March 3rd, 2017, 10:18 AM
  #85
young olds's Avatar
My rocker shaft supports and aluminum flywheel came in yesterday.
If the weather holds out I might drop the engine into the car and make my motor mounts and tranny mounts this weekend.
Old March 3rd, 2017, 11:53 AM
  #86
young olds's Avatar
Old March 10th, 2017, 04:28 PM
  #87
young olds's Avatar
Picked up my axle shafts today, was successful in redrilling to 5x4.75", still need to redrill the drums, pick up tires and mount them so I can bolt them on then the rear is done and off to the front.
Old March 12th, 2017, 12:37 AM
  #88
young olds's Avatar
I finally got the 5 lug conversion done on the year, was able to bolt a wheel on to see what size flares I'll need
Old March 12th, 2017, 09:51 AM
  #89
64Rocket's Avatar
where did you find the rocker supports and what is the cost?
Gene
64Rocket is offline
Old March 12th, 2017, 10:32 AM
  #90
young olds's Avatar
I got them from D&D for $200, seems pricey when your holding them in your hand but idk who else you can get them from and they probably dont make enough to get machining cost down.
Old March 15th, 2017, 04:56 PM
  #91
young olds's Avatar
Put tires on the wheels.
Old March 15th, 2017, 06:38 PM
  #92
jensenracing77's Avatar
Going to be a sweet ride.
jensenracing77 is offline
Old March 15th, 2017, 09:35 PM
  #93
young olds's Avatar
I know it's not the style most people around here will like but I'm enjoying it so far
Old March 18th, 2017, 09:51 PM
  #94
young olds's Avatar
Was able to make some progress today.
Old March 18th, 2017, 10:10 PM
  #95
64Rocket's Avatar
So that is the Buick engine?
I was thinking you had the Olds engine.
But Buick engine fits the Buick Opal. Looks good.
Also, do you plan on wheel flares or as is?
Gene
64Rocket is offline
Old March 18th, 2017, 10:26 PM
  #96
young olds's Avatar
It's an olds block with Buick heads and obviously valve covers, I wanted to bump my comp up its about 10.14:1. It doesn't really fit, I cut the oil pan and made it a rear dump and I had to modify the crossmember. And yes absolutely flares, just need to buy them.
Old April 30th, 2017, 09:29 PM
  #97
young olds's Avatar
Progress has be very slow, been having to sell other parts to make some spending money. Sold my old appliance wire wheels and made enough to buy front tires and I should have enough left over to buy the brake parts that work with the five lug swap.
Old April 30th, 2017, 09:30 PM
  #98
young olds's Avatar
Btw motor mounts and tranny mounts are done
Old April 30th, 2017, 10:13 PM
  #99
64Rocket's Avatar
Did you use something to get disc? Or did you just redrill the hub asy? If you redrilled the hubs how much room on the hub is there from the edge?
Gene
64Rocket is offline
Old April 30th, 2017, 10:47 PM
  #100
young olds's Avatar
I put the old drum brake hubs off my 66 on the front, took minor machine work and new bearing sets. Brakes will be front calipers and rotors off an early 2000's grand am. All said and done it's a five lug swap and brake upgrade, stock disk set up fits inside 13" wheels.
Old May 3rd, 2017, 04:31 PM
  #101
young olds's Avatar
Picked up my front brake parts today and installed some h4 headlight housings.
Old vs new calipers and rotors
Old May 3rd, 2017, 04:56 PM
  #102
young olds's Avatar
I've been trying to track down history on my engine, the original I started the thread about, the guy I got it from never ran it and got it as payment for work he provided. I got the name and number of the guy he got it from and called him today. He said he bought the car, a land speed car raced at bonneville, but he never ran it either he decided to pull it in favor of another engine. But the cool thing I found out is that he bought the car from Jim lattin who ran the car with my little 215 in the 80's and early 90's. I personally don't know much about land speed racing or Jim lattin but my limited research shows he has quite a big name in land speed racing and bonneville.
Old May 3rd, 2017, 05:52 PM
  #103
Love it! Does the guy still have the car the engine came from?
Old May 3rd, 2017, 09:09 PM
  #104
young olds's Avatar
Yes, the guy I spoke with(bill) is in his early 80's now. He told me he bought it from Jim lattin in the 90's. After looking into trying to crank out even more hp from the 215 he figured he could go faster cheaper with a sbc so he promptly swapped it, he said it's currently running what is basically a NASCAR sbc( im assuming sb2) cranking out a bit more than 700hp. Iirc he said the car is called white lightning, he also told me he's pretty sure he still has parts for the 215 he'd just give me but he has to go to his hanger and look for them.
Old July 3rd, 2017, 12:03 PM
  #105
young olds's Avatar
i tried to start the engine yesterday with no luck. seems to be ignition related, it acts like the ignition is off while cranking but if i pull a plug and gound it to watch fo a spark it kinda acts like its want to fire but spark seems kind of week. all the ignition parts are new, any ideas?
Old July 3rd, 2017, 12:55 PM
  #106
Points? Gapped properly? What voltage do you have key on and cranking? Grounds?
Old July 3rd, 2017, 01:15 PM
  #107
young olds's Avatar
Points are gapped properly, haven't checked voltage while cranking. Have two nice grounds from engine to car.
Old July 8th, 2017, 10:35 PM
  #108
young olds's Avatar
Figured it out, I didn't have a condenser
Old July 9th, 2017, 08:46 AM
  #109
How does it run? I replaced the module for my 260, the other was toast. No fire, went back to look at it, I didn't plug in the pick up coil, instant fire when hooked up. Stupid little mistake but makes all the difference.
Old July 9th, 2017, 09:17 AM
  #110
young olds's Avatar
Seems to run well, I still need to hook up the fuel system so I can run it longer and do timing and adjust the carb.
Old March 27th, 2018, 12:54 PM
  #111
young olds's Avatar
Still working on this, have been focusing on headers but have been doing other things here and there. I’ll post pics soon
Old March 27th, 2018, 08:26 PM
  #112
64Rocket's Avatar
What master cyl did you use on the F85 to convert to dual master?
Gene
64Rocket is offline
Old March 28th, 2018, 04:48 PM
  #113
young olds's Avatar
C3 corvette, they could be ordered with 4 wheel manual disk brakes.
Old March 30th, 2018, 05:50 PM
  #114
young olds's Avatar
Finish welding the headers today and hooked up the x pipe so I could hear it. Will be doing mufflers soon if I have room.
I found a build that is very close to the same as mine, it made 235hp and 232tq, I’m hoping with the differences I’m still in the 220hp range.
Old March 25th, 2019, 07:44 PM
  #115
young olds's Avatar
Small update
I was getting water in my oil due to a hole in the timing cover behind the water pump. So the engine was pulled, I needed to pull it anyways to finish the engine bay. As of today I have the engine mostly back together and the engine bay is done.
Old November 9th, 2020, 07:42 PM
  #116
young olds's Avatar
july 2019 i was driving home from stancewars in bellevue and about 3 minutes from home a valve keeper let go and a valve dropped, the piston used the valve like a bouncy ball. after tear down the valve seemed straight but the piston had a perfectly round valve relief so i decide not to test my luck with any of it and built a new engine. i bought a 63 cutlass with a supposed rebuilt 215, I think the guy just disassembled it, washed everything and reassembled it with new gaskets and arp head studs except he left in two factory bolts among other strange things like the first two rods and pistons were installed backwards. After sorting the engine out i installed my new/performance parts from the old engine, fell into a lot of MAW's while the engine was out. rebuilt the suspension with a combo of polyeurethane and few aluminum bushings, cut my inner fenders out, relocated my front shock, myself and a 2x10 fell off a roof and landed on the front of the car resulting in me obtaining fiberglass fenders and hood, i had the stock radiator re-cored to a three row, my buddy welded up a coolant surge tank, i went from electric fan to mechanical clutch( i could not keep the engine cool if i let it exceed 200* even on the freeway so i cant blame just the fan) which required moving the radiator further forward, in addition the the mallory dist. i added a winterburn cd ignition, ditched the factory master in place of a willwood, added a harness bar for 5 point harness. Probably forgetting things but i finally was able to take in on a test drive yesterday, drove a few blocks away and back, seems to run pretty well but not quite like my last engine.
Old November 9th, 2020, 07:52 PM
  #117
young olds's Avatar
the pictures from the last post are from last year/ealier this year, as are these
these are from the last month or so. i built a set of OZ racing vega wheels, 15x8 and 15x10. i ditched the universal/s30 flares in favor of steinmentz box flares, btw ordering a hood and two fenders that are shipped in one big box from germany is a hassle on top of expensive.
I want to run it with the engine the way it is for a while(get used to it) then switch to a single plane intake(same carb) then ultimately switch to my 4 dellorto drla carbs on my harcourt downdraft intake, curious to se the difference in driveability and seat-o-the-pants hp changes if any.
Old November 9th, 2020, 07:56 PM
  #118
Registered car nut
nonhog's Avatar
Plan on keeping the factory (?) paint and stripe? I think it looks cool. Bummer on the accident but nice excuse to buy lightweight parts!
nonhog is offline
Old November 9th, 2020, 08:11 PM
  #119
72 Olds CS
RetroRanger's Avatar
the car is looking pretty wild man thanks for posting
RetroRanger is offline
Old May 24th, 2021, 08:56 AM
  #120
72 Olds CS
Did you see this electric opel ? Its looking pretty cool too
https://www.yahoo.com/autos/opel-man...145900344.html
Quick Reply: Just bought a sweet 215
