Speedmaster Valve Springs???
Old April 28th, 2015, 07:56 AM
rab62184's Avatar
So, I'm looking for some valve springs on the cheap to throw into a set of iron Ga heads for my 455 to get the cam that Mark (cutlassefi) custom did for me (.568" lift). While he offered quality components to complement the cam on the iron heads, i needed as cheap of an alternative as possible. I found these springs on the speedmaster website:
http://store.speedmaster79.com/p-249...coil-bind.aspx
They seem to be what i'm looking for, however,i need locks and keepers! What is your take on these springs, and do ya'll have any suggestions for locks and keepers? I'm trying to keep this on the super cheap as i'll be replacing the heads in the future with procomps.
rab62184 is offline
Old May 16th, 2015, 06:50 AM
cutlassefi's Avatar
Seat pressure is little high for a hyd flat tappet. Do they list open pressure anywhere?
cutlassefi is offline
Old May 18th, 2015, 08:17 PM
NHRA W-30's Avatar
A bit of info-- I've had bad experience w/ aftermarket valve springs for my '70 w-30 stock eliminator car . I'm only using an Olds factory race cam w/ 475 lift . The aftermarket springs I've tried [ Crane and Comp Cams } worked great when new, but after 40-50 runs , they give up pressure at high RPM and cause lifter problems . The problem appears to be poor quality steel these days -- my factory w-30 springs last for years . If you're not racing or gonna run your motor hard, use anything that floats yer boat . If you're serious w/ a high reving stocker changing springs and lifters a couple times in a season sucks!!
NHRA W-30 is offline
Old June 3rd, 2015, 06:23 AM
rab62184's Avatar
They didn't on the website, but I did find the listing in their master catalog.
SMS2005_ 1.450” Dual Spring w/damper, 145lbs.@1.900”, 420lbs.@.600” lift, 1.150” Coil Bind
SMS3005_ 1.450” Dual Spring, 200lbs.@1.800”, 450lbs.@.500” lift, 1.175” Coil Bind
SMS5005_ 1.285” Single Spring w/ damper, 125lbs.@1.750”, 335lbs.@.500” lift, 1.080” Coil Bind
SMS6005_ 1.450” Dual Spring, 130lbs.@1.800”, 335lbs.@.600” lift, 1.060” Coil Bind
SMS7005_ 1.550” Dual Spring, 150lbs.@1.900”, 390lbs.@.600” lift, 1.125” Coil Bind
SMS7400_ 1.550” Dual Spring, 250lbs.@2.050”, 725lbs.@.800” lift, 1.175” Coil Bind
SMS7500_ 1.550” Dual Spring, 275lbs.@2.100”, 850lbs.@.800” lift, 1.175” Coil Bind
SMS8005_ 1.550” Single Spring w/damper, 130lbs.@1.900”, 280lbs.@.500” lift, 1.125” Coil Bind
SMS9005_ 1.635” Triple Spring, 300lbs.@2.050”, 625lbs.@.650” lift, 1.325” Coil Bind
SMS9200_ 1.300” Dual Spring, 150lbs.@1.800”, 385lbs.@.600” lift, 1.050” Coil Bind
SMS10005_1.270” Conical Spring, 150lbs.@1.800”, 260lbs.@.500” lift, 1.240” Coil Bind
SMS11005_1.290” Dual Spring, 140lbs.@1.800”, 270lbs.@.500” lift, 1.180” Coil Bind
Doing some quick math tells me that the spring rate is approximately 342 lbs/in. If I set the spring install height at 1.875" (assuming i can get that far), that should put seat pressure at 105 lbs. with a pressure of 299 lbs. at .568" lift.
I called the guys at Speedmaster (procomp) and they said this is the combo that they use on their oldsmobile heads. what really sucked was that i had to call 5 or 6 times to reach their "tech guy" instead of an order-taker.
I don't know, maybe I do just need to bite the bullet and get some more expensive valvetrain components? With all the cost, my machine work is sitting in the garage in a bag, rusting away because of houston humidity.
rab62184 is offline
bigjaythe1st
Suspension & Handling
May 8th, 2012 05:45 PM
1acesmith
August 11th, 2011 11:03 AM
jensenracing77
March 13th, 2010 12:41 PM
rcdynamic88
February 18th, 2010 07:46 AM
Redog
December 29th, 2008 06:32 PM
Quick Reply: Speedmaster Valve Springs???
