Carb for this
Old December 20th, 2014, 01:36 PM
Shradezz70S's Avatar
Carb for this
I am trying to decide on a carb for my 455. What are others running for a pro Turing olds ? This is what I have
455 30 over
Icon ic 886-030 forged Pistons
eagle rods
Comp 42-224-4 cam .520 .523 dur .050 230in 236 ex
Comp 825-16 lifters
Comp roller rockers
Comp 7183-16 push rods
Arp bolts
Edelbrock rpm heads
Edelbrock rpm air gap intake
MSD ready to run distributer
AMR 1 7/8 tube headers
I was leaning to a Holley 800cfm 4150 but would like to here what others would recommend.
Shradezz70S is offline
Old December 22nd, 2014, 07:11 AM
oddball's Avatar
IMO...........
Lots of carbs will perform similarly. It's really up to what you can tune, or have tuned, well and properly maintained. Your build is not wild, so you can grab pretty much any 650 - 850 carb you want.
QJet has the bad rap because it's a relatively complicated carb. Set it up wrong and it's terrible. Set it up right and it's great. Getting good cores can be a problem.
Holleys are all over the place and you can get parts off the shelf at the local parts store.
The new Street Demons look really interesting. Should be between the Edelbrock and Holley in complexity, but get street manners closer to a QJet.
I'd say skip the Edelbrock carbs, but they're good for just getting an engine running, and are easy for a novice to tune. It took lots of compromises to get there.
You said pro touring. One separate consideration is if the carb will be on display. If so, then your taste in appearance may be a factor. The good QJet shops can replate the carbs so they have the nice yellow-ish shine. The new stuff is always available in multiple finishes.
In the end I strongly urge folks to go with a carb that either they have experience tuning, or have a good friend that can tune well. Proper carb tuning is very important. "Out of the box" is almost always BS.
oddball is offline
Old December 23rd, 2014, 06:06 AM
cutlassefi's Avatar
Quick Fuel Super Street 850, which is really about 880.
cutlassefi is offline
joepenoso
July 19th, 2013 12:44 PM
Don R
October 6th, 2012 09:47 AM
RandyS
October 4th, 2012 12:36 PM
Quick Reply: Carb for this
