looking for turbo info 425--455???
Old September 27th, 2014, 08:33 AM
swat455
steve walker's Avatar
hello .. was looking for a thread on turbo 455s and was just wanting to know has anybody here done this? as Im thinkin of doing this to another 425 I have and poss efi
steve walker is offline
Old September 27th, 2014, 12:23 PM
cutlassefi's Avatar
One question, how much power are you looking to make?
cutlassefi is online now
Old September 27th, 2014, 06:24 PM
allyolds68's Avatar
http://realoldspower.prophpbb.com/to...ml?hilit=turbo
http://bangshift.com/bangshift1320/w...early-testing/
allyolds68 is offline
Old September 27th, 2014, 09:53 PM
young olds's Avatar
sleeper 65 4 door
http://realoldspower.prophpbb.com/topic273.html
rear engine pick up
http://realoldspower.prophpbb.com/topic260.html
there are more if you look
young olds is offline
Old September 27th, 2014, 09:54 PM
swat455
well as far as power Im thinking of at least 550hp to the wheels adj boost/waste gate for idle and max power. multi port efi as too a blow thru carb. using the 425 block, crank, alum heads ,crosswind manifold, forged pistons of about 9 1/2 to 1 maybe 10 to 1 . gapless rings , oil squirters to pistons , crank mods , and well as far as pipe plumbing there is lots of room in the starfire im just stuck on if it will be a turbo, supercharger or diesel with turbo , or an ls with turbo... which do you think would the cheapest to build ,give me the most power, last the longest , and the most mpg.........just tired of filling up bottles and if im a car chase with bikers and what not. trying to run me off the road to get my gas . it would be better to have non stop boost than an empty or cold nos bottle in that case lol..................
Old September 28th, 2014, 07:10 AM
cutlassefi's Avatar
Scrap the 425 block, use a DX. A little more machining but much much stronger. Keep the 425 crank though.
I'd use Edelbrocks, a Victor, and 9.0:1. If you need help with the EFI let me know. If you plan on doing that anyway then I'd do it right away. That way you're not buying stuff twice.
80_cutlass
March 17th, 2011 06:03 PM
sx455raidercelticfan
August 1st, 2010 08:03 PM
Liegekiller
15
June 27th, 2009 07:58 PM
Liegekiller
May 30th, 2009 05:31 PM
Quick Reply: looking for turbo info 425--455???
