Olds type "O" rear end gears
I have a set of Richmond 4.10 gears for a type O rear end for sale. Apparently Richmond is months behind on production for the type O rear end, and I have no use for these. If anyone is interested please message me. I also have the posi carrier for the type O but it does need to be rebuilt. Make me a good offer and its yours. Thanks.
gears
The carrier is stamped with 588 if somehow you can tell which carrier that is and the gears are stamped right from Richmond. I do know that it is a type o rearend because I also have the entire housing.
588 carrier
The 588 carrier is the "big" one for the numerically higher gears (3.42 and up). IIRC from a conversation with Bryan Trick last year, the Richmond ring gear will need to be milled .010" on the back side to fit properly. Double-check with the rear-end specialists on here before cutting, LOL!
350TurBRO
September 12th, 2014 11:52 AM
L77F85
Drivetrain/Differentials
16
November 29th, 2013 06:19 AM
