Help on opening up oil drain back holes in heads
Old April 2nd, 2014, 07:40 AM
rootney's Avatar
I need some guidance from some of you seasoned veterans please.
I'm about to install "C" heads back on 455 block and re-install in my '72 Cutlass.
This has been a Carb to oil pan rebuild for a hot street setup. Everything's coming together nicely with just a bit more to go before pulling the 350.
I just finished up some port and polish and Xover filling on the heads, Inspired by the "Home Porting Techniques" thread by 67 Cutlass Freak (thanks Dave). BTW, this forum has been absolutely awesome helpful. I'm turning 60 this year and this is the build I've always wanted to do. I'm having a ball.
Opening the oil drain back passages in the heads is something that I'd like to do now as well.
Beside needing a recommendation on drill sizes, any tips or techniques would be appreciated.
I've not found any detailed info in my searches. Some guys have reportedly broken into one or more of the Head bolt holes when doing this.
Thank in advance for the advise,
George
rootney is offline
Old April 2nd, 2014, 08:57 AM
455man's Avatar
http://www.robertpowersmotorsports.com/Tech1.html
I just used a 3/8 drill bit and smoothed out the holes. Also smoothed the openings going to the drain holes. There was a lot of sludge in them.
455man is offline
Old April 2nd, 2014, 09:35 AM
rootney's Avatar
That's a good link.
Anyone agree/disagree?
George
rootney is offline
Old April 2nd, 2014, 09:58 AM
costpenn's Avatar
Originally Posted by rootney
That's a good link.
George
Could not agree more about cleaning out the holes well. A couple of years ago, a friend was finally putting together his 68 400. He sent his heads to Mondello to get some kind of super porting and polishing work, and was told that Joe himself did the work. Anyway, the heads sat for a few years before the engine assembly, so I pulled all the valves and looked at the seals/guides to check for cleanliness and contamination. Everything was fine there, but just as an afterthought ran a pipe cleaner through the two big drain back holes on the end. Thick wads of sludge, metal filings, green roto loc fibers and even a small piece of a red shop towel came out of those holes. I'd imagine the flow rate through the holes wasn't half of what it should be.
costpenn is offline
Old April 2nd, 2014, 10:03 AM
rootney's Avatar
You mean all that crap stayed in there even with a bath post machining?
George
rootney is offline
Old April 3rd, 2014, 10:57 AM
Engine Builder
Smitty275's Avatar
The Bob Powers link is basically sound information. Just be sure to head the warnings he gives about opening up the oil return holes. You must be careful to follow the existing hole because it is very close to water. AND its a bitch to fix it if you go through.
Smitty275 is offline
Old April 3rd, 2014, 12:23 PM
Run to Rund's Avatar
I prefer to restrict oil flow upstairs with lifters that meter the correct amount of oil.
Run to Rund is offline
Old July 27th, 2014, 08:02 PM
sbceater's Avatar
Lol i just used a burr bit and got rid of the ledge
sbceater is offline
Old August 11th, 2014, 12:43 PM
tonycpe's Avatar
the ledge is there for a reason.
tonycpe is offline
Old August 21st, 2014, 09:45 AM
sbceater's Avatar
What reason lol
sbceater is offline
Old August 21st, 2014, 10:00 AM
Octania's Avatar
I don't think breaking into a head bolt cavity would be a problem. Hot oil might get on the bolt. OOOH...
Now a water passage, that's s problem.
I have seen aft end of head drilled and tapped NPT then plumbed a drain tube down to the block near the oil pan. LH side, so the crank throws the return oil into the pan.
Octania is offline
Old November 19th, 2014, 10:43 PM
buzzbomb's Avatar
Talking
Ya have to have somewhere to set your beer on!.
buzzbomb is offline
Old November 20th, 2014, 12:39 AM
'87 Delta 88 Royale
rustyroger's Avatar
I'm thinking of all the threads concerning running hot while I'm reading this.
Just like a radiator that isn't partially plugged will be fine with any engine rebuilt to OE spec, so properly cleaned out oil return holes should have no problems with a near stock setup. If you have a high pressure, high volume pump I still think it shouldn't send more oil to the heads than it can cope with as long as the drains are clear and you aren't using high viscosity oil.
This is only my opinion mind, I have built precisely one non diesel Oldsmobile engine.
A head sent to an acknowledged builder coming back with clogged return holes?. I am rather surprised, and also a little disappointed to read that.
Always check everything when you get your parts back, no matter who did the work should be a mantra we all follow I guess.
Roger.
rustyroger is offline
cwb442
February 9th, 2015 01:39 PM
66-3X2 442
October 16th, 2014 02:57 PM
brandon 455
July 14th, 2013 04:16 PM
geckonz08
November 25th, 2009 09:01 AM
prawnman88
April 27th, 2007 07:54 PM
Quick Reply: Help on opening up oil drain back holes in heads
