Cam help!!
Cam help!!
what would be a better choice for cam?
its a 455 .30 forge pistons 9.1 Edlebrook heads, performer intake , 750 QF, th400 307 gear..I will be changing gear and stall..this will be a weekend driver only with a/c inned it to go and sound good
I'm looking at
voodoo 60803
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 227/233
Gross Valve Lift (Int/Exh): .510/.522
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1600-5800
Modello jm 20-22
0.4960.512266°/274°226°230°110°1400-5800
Modello jm 20-25
0.5120.523274°/280°230°236°108°1400-6000
im open to a recomindation Comp cam etc
I'm looking at
voodoo 60803
LSA/ICL: 110/106
Modello jm 20-22
Modello jm 20-25
I used a cam very simular in a 355 SBO, ran well sounded great, I believe it will work for your application.
I prefer a 60811 or 60812 Hydrolic roller for better performance and power.
We also offer a custom WPE .842 Hydrolic roller lifter, WPE 3/8 cro-moly pushrods and Roller rocker in a kit to match. .02
I had that cam in a 10.25 to 1 355 and loved it. You could hear it but great manners and driveability. It should be great in a mild 455. Some say (Mark) that the steep ramps are hard on the valvetrain, perhaps true. And, a roller IS better, if you can afford it.
67flamedcutlass
December 19th, 2019 07:54 AM
