Home Porting Techniques
#482
So what you are saying is you are arguing for the sake of arguing ? Im having dejavu. I kinda skimmed through the back and forth so from what I gathered it took a few post for everyone to agree he has what he has.
#483
I NEVER said I was STUCK with it. I built a small CUIN olds engine and went faster than any one else with 400 cuin naturally asperated full body 3400 lb 10" tired car. We went just as fast and in somecases faster than guys with 480 plus inch big blocks running cars within the same perameters. Besides that I was refering to the 350 in this thread.
Greg
Greg
#484
No, what Mark and I are both saying is that yes, CutlassFreak has this big-domed short block and is using what he has, but in both of our opinions, there are better ways to achieve a high compression, high horsepower engine without the inherint issues that come with those big domes.
#485
OK I want to see you and mr efi's big hp combo's greg has done it with domed pistons so where are yours ? This comes down to theory vs. actual experience . You can think there is a better way and there probably is but have you built an engine of that caliber ? It's like the seasoned mechanic vs the out of school tech the tech knows theory but the seasoned tech knows experience. Im not saying I will ever build an engine like greg's or even like mr freaks but to each his own.
#487
Moving Foreward
To Mark and everyone else - If you were in my shoes, and wanted to finish this engine without spending too much more money, what recommendations would you have. If I was able to go back in time, I would have done things a little different. First I would have built a stroker with Chevy rods and flat tops. The young man that I was helping build this engine, picked the pistons with our machinist's help. The short block is assembled. The cam has been degreed in. I realize that it may have to come back apart for clearencing. I really like Smitty's way of calculating the dome. I will do that. This engine kind of fell into my lap. Yeah I paid for it, but I never wanted it. I don't have a use for it. We're getting a little off the subject here of "Home porting Techniques" but it's probably OK to touch on some of this, so that guys will know what's involved with trying to fit a size 12 foot into a size 10 shoe. Maybe I should have started a different thread, but I didn't realize how adamant you guys would be over these Mt Rushmore pistons.
#488
#489
#490
Greg
#491
For the record, one last time. If you're looking for that high of a compression ratio, then as has been mentioned already a dozen times, you're most likely stuck with what you have. Make the best of it, plain and simple.
For the rest, please don't put words in my mouth. I'm pretty sure that if a big dome was the ticket for the best power, apples to apples, then I'd be willing to bet all the best engine builders in the world would do them that way. The fact is they don't, not unless they HAVE to, based on available heads, pistons and desired compression ratios.
Of all the most popular, highest output engines designed from a clean sheet of paper in the last 10 years, how many have this configuration? Hmmmm....check it out for yourself.
Done here.
Done here.
#492
Jim I jumped in because you guys are at it again . I want to see what you have done first hand in that range of power that make your opinion come from actual first hand experience. Im questioning you not starting anything.
#493
My mother taught me at a very young age if you don't have something nice to say don't say anything at all.
#494
Done here.
Done here.
Greg
#495
OK guys I think we can all agree that we love Oldsmobiles. There's different thoughts and opinions on how to make them go fast or last. Let's please stop bickering. I know you guys feel strongly about your own accomplishments. I think that everyone here is truly wanting to help. Noboby on this board wants to see another Olds engine fail (Except maybe Nick). You know I'm just kidding. I love you guys. Seriously though I'm very interested in what specific clearances I should be shooting for. Valve to piston, piston to head minimums. Do you guys think we should have gone bigger on the cam? Don't fault Mark at all for that. When he helped me choose the cam we had no idea what kind of car this thing was going in. Still don't know for sure so we were guesing heavy G body with a tubo 350 and 390ish gears. Jim by the way the heads I'm going to use are ported GA's. Everybody lets try to work together to keep this thread informative and not clutter it up with BS. Please post information that you think the entire Olds community would benefit from viewing. I really don't want Oldcutlass to have to come in here and start deleting posts again. I'm sure he's getting tired of that.
#496
Ahhhh so that's who you are Greg, no wonder about not knowing crap. Why don't you tell them the whole story. Your vast knowledge, 9000 rpms did not pan out with piston/head clearance. Never lasted long did it?
#498
Piston to head .040 minimum for a stock steel rod engine. Piston to valve .100 min on exhaust and .080 on the intake. Your much more likely to smack an exhaust valve, especially if your bouncing it off the seat/floating it.
#501
Well I must say I'm glad to see Greg/rcktdoc back on a forum. He has a lot of good back ground and is a good guy. Hell of a body/paint guy and knows the intricacies of the Oldsmobile a bodies very well. Greg was the ORIGINAL Olds wheel stand champ.
Sorry I can't say the same for Nick/380 racer.
#503
I've been following this thread from the start, very informative and a bit entertaining too..
There is a wealth of info here for backyard guys like me that just wanna do a bit of cleaning up so we can get that " I ported my own heads " warm fuzzy feeling when we drive our rides down the street, without going the whole max cfm flow racing job. Thanks guys.
I have a pair of '73 J heads off the car atm and a pair of '68 red 455 C heads sitting in the shed. also have the option on a pair of 425 B heads. Both B& C heads have 2.0" inlet valves.
Before I get out the dremmel, which heads would be the best to put back on. I'm confident to do a bit of cleaning up after watching this thread-nothing ott like you guys tho.
I'm thinking of a cam-a bit better than the smog one currently in there, pistons to raise the cr to about 9:1, a performer ally manifold and dual or large single exhaust. I'm keeping the Q-jet 800cfm 4v she came out with.
Just swapped the open rear out with a posi 3:23 center. Only a Saturday night street cruiser.
What would be the minimum port work I could get away with on one of the above heads?
Thanks again guys.
Thanks again guys.
#504
The best answer that I have for you is......The ones with the best valve guides.
#505
Thanks again guys.
Thanks again guys.
http://www.ebay.com/itm/380867230247...84.m1423.l2661
#506
Thanks for that guys.
Yeah I'd figured on a 3 angle valve grind. I have an electric cable drive grinder as well with a lot more grunt behind it, I'll use that instead of the dremmel. i have access to an engineering shop so I'll make a nuisance of myself there.
cheers.
cheers.
#507
I have a cable drive also, but it didn't work out so well. Not enough RPM and the cable limits free movement and control. Didn't work too well for me. The Dewalt that I posted a link to is kind of bulky, but if you don't have a compressor it's a good option.
#508
well i must say i'm glad to see greg/rcktdoc back on a forum. He has a lot of good back ground and is a good guy. Hell of a body/paint guy and knows the intricacies of the oldsmobile a bodies very well. Greg was the original olds wheel stand champ.
Sorry i can't say the same for nick/380 racer.
rotflmao
#509
The Dremel tool will work for you in the bowls if you use cut off wheels and keep it moving. It will definitely take longer than a big ol' carbide burr, but you can get it done.
Don't bother putting those wimpy 1/8" cutters or stones in them though. You'll find out fast that they're a total waste of time.
#510
I used a Right Angle die grinder with carbide bits to remove bulk metal.
Switching to a dremel with flex extension for finer work.
The RA grinder and flex shaft allow almost all the work to be done from a stool instead of standing. Big help with fatigue. You can go longer with more consistent quality.
George
George
#511
A Dremmel, really. You guys are kidding right. There is no way on God's green earth I would even consider it. At least go to Harbour Freight and buy a cheap die grinder and couple of carbide burrs. Will save you thousands of hours.
#514
trial fit
I've never tried a Dremel tool for porting. Those bits are very small, and it only has a 1/16" shank. I'm with Smitty on this one. I know Joe Mondello used to do a lot of porting with the electic type of grinder that I posted a link to. I don't own one but they look pretty big and bulky to me.
I was messing around with the GA heads that I ported. Did a trial fit on some valves. The intakes are 2.12" and the exhaust are 1.68" I may end up using 2.07" intakes, but this fit pretty good and there's .035" gap between them. Now I really have to dig out the 350 and check the valve reliefs.
#518
Anyone wanna buy a snap on carbide set for 120 ? Never used. Also I was talking about the grinder from hbt. Not the carbides lol. I would not trust any bits from them .
#519
Cylinder head stand
In the beginning of this thread I started off by discussing comfort and safety. I own a set of post type cylinder head holders. I'll be damned if I can find them. I haven't seen them for years. So yesterday I spent about 1/2 hour during my lunch break to make this head holder from some scrap steel. If anyone wants the dimensions, I will be glad to post them. I used some heater hose to protect the head. It works excellent. I used it all day today.
#520
Touch up
Today I spent some time going over the port work on my GA heads. If you've been following along then you know the story on these heads. I pushed the width out as far as I could on the intake ports. I was getting nervous with how close to the push rod holes I went. I didn't punch through anywhere. I also did a rough cut out to 2.07" valve size and opened up the bowl a bit more. I will probably end up going with the 2.125" valves, but I need to dig out the SB engine these are going on to, and make sure the valve reliefs are large enough. Here's some photos-
J(Chicago)'s heads are at the machine shop having the guides installed. When I get them back we will do the valve job. In the meantime I'm going to finish the port work and valve job on these GA's then we're off to the flow bench. I will post all our results here, good or bad. I am hoping for the best. I'm sure there will be some inconsistency across the ports on each head. I will most likely try to equalize the flow numbers, but I don't know if they will make it back to the bench for a second time to verify my work. The bench time costs money, and everyone involved with these heads is on a tight budget. Including myself.
