394 engine ohaul
Old March 7th, 2017, 01:22 PM
dennis_30281's Avatar
394 engine ohaul
Hi All,
I have a 394 green engine with a four bbl carb and I want to upgrade to a 10:5 comp ratio and 345 HP version. I want a turn key rebuild. I afraid of Mondello and leary about local or some Classic Olds shops. Any suggestions. Thanks
Dennis
dennis_30281 is offline
Old March 7th, 2017, 02:42 PM
Tedd Thompson's Avatar
Just curious what transmission are you running behind that 394? Most Slim Jims were problematic when young, add a bunch of years and a fresh worked engine in front of it and longevity isn't what you get.You might want to give Tony a call at Ross Racing Engines. He knows more about these first generation Oldsmobile's than most.... Tedd
https://rossracingengines.oursafeserver.com/
Tedd Thompson is offline
Old March 8th, 2017, 07:37 AM
Thank you for the heads up. I talked to Tony and he will upgrade the engine and provide an adapter plate and a modern o/drive trans.
Thanks again
Dennis
wr1970
March 29th, 2015 05:36 AM
805cut
May 3rd, 2012 08:11 PM
trackz man
December 13th, 2010 12:45 PM
Quick Reply: 394 engine ohaul
