spark plugs
Old February 25th, 2017, 05:25 AM
oldman8187's Avatar
spark plugs
Can anyone suggest the best plugs to run in my 350 Olds pro comp 77cc heads. Engine has flat top piston mild cam 520 lift 110 lobe separation and 750 holley?
oldman8187 is offline
Old February 25th, 2017, 07:41 AM
I run AC Delco R45S in my 455 gapped to about .045". I'm not sure if a small block would need different plugs.
Olds64 is offline
Old February 25th, 2017, 06:02 PM
oldman8187's Avatar
pro comp used the 5/8 plug with .750 reach but I am not sure what is best plug for my build?
Old February 25th, 2017, 07:44 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
So around 9 to 1 compression, I would run a hot plug. You probably need less timing with the more efficient chamber, I like a lot part throttle with factory Olds heads. These would probably work. https://m.summitracing.com/parts/ngk...ns?prefilter=1
olds 307 and 403 is offline
Old February 26th, 2017, 05:57 AM
oldman8187's Avatar
Thinks I will give them a try and I did try a little less timing seemed to help part throttle.
Old October 21st, 2021, 07:41 AM
jskorz's Avatar
Thanks to all for your reply's ....
My reason for not using Champion plugs goes back to mid thru late 70's I was a flat rate mechanic @ an Olds dealer . The parts dept. went to Champ. plugs to save $ , I did more then 1 tune-up where the car ( Oldsmobile ) came in running fine ran like crap after replacing the plugs with Champs ( only under a load would break down ) I would replace them with AC plugs car ran fine - would loose my A$$ on a simple tune-up which would normally be a money maker , but yet they were fine in Chysler products and small engines don't know why ?
jskorz is offline
Old October 21st, 2021, 07:51 AM
fleming442's Avatar
Been using Autolite in my Edelbrocks for some years now. 3922, 3924, or 3926 depending on how much heat you need/want.
fleming442 is offline
Old October 21st, 2021, 05:29 PM
olds_freak's Avatar
Same here.
olds_freak is offline
Old October 22nd, 2021, 02:00 PM
cutlassefi's Avatar
Start with NGK 4644’s and go from there.
cutlassefi is offline
Old October 23rd, 2021, 11:57 AM
jmcghee's Avatar
Early 80s I was assistant service manager, at a Ford dealer. We had the same problem with champions in a Ford.. Autolites ran fine
jmcghee is online now
Old October 23rd, 2021, 06:44 PM
cutlassefi's Avatar
Then you had the wrong plugs in it. The plugs aren’t human and have no idea what “brand” engine they’re in. That’s the stupidest thing I’ve ever heard. You had the wrong plugs in it, or they were simply defective, plain and simple.
Old October 24th, 2021, 04:24 AM
jmcghee's Avatar
champion plugs
If that is the stupideest thing you have heard , you sure dont get out much. They were defective , that is true . Large batches of them
Old October 24th, 2021, 06:08 AM
cutlassefi's Avatar
They were defective, that is true. Large batches of them
Then just say they were defective then. Don’t suggest they actually “knew” what brand of engine they were in. C’mon man.
jskorz
October 22nd, 2021 02:03 PM
Noel Anderson
February 27th, 2021 03:54 PM
madmax442
Non-Olds Engines
June 3rd, 2015 04:27 PM
HWYSTR455
July 13th, 2014 09:46 AM
72442clone
July 15th, 2011 11:53 AM
Quick Reply: spark plugs
