The new guy wanting 500hp
Old February 5th, 2017, 10:50 AM
MonteCarlo_Nate336's Avatar
Hey guys was trying to get some information. My name is Nate/MonteCarlo_Nate and was wondering what needs to be done to achieve 500hp out of a 71 Olds 455 (396021F).
I was planning on changing camshaft (not sure which yet). Double roller timing chain, new performance intake, getting crank balanced, grounded and polished. Stuck pistons unless stocks are not perfected or damaged. Currently has 750 Holley vacuum secondary. Wanted to either get C heads or keeping G heads and get ported milled, polished and valve job. All information will be greatly appreciated.
MonteCarlo_Nate336 is offline
Old February 5th, 2017, 05:04 PM
I moved your post to the performance section. If you do a search you'll find a lot of info already out there in addition to what ever answers you get with this post. Post a proper intro with pictures when you get a chance.
oldcutlass is online now
Old February 7th, 2017, 03:57 PM
74sprint's Avatar
500Hp
A great place to start would be to read through this thread: https://classicoldsmobile.com/forums...ld-thread.html These are engine builds that members have posted, depending on the weight any car running low 12's or high 11's will be 500 shp. I have stock 'G' heads on my car and they flow 221 cfm which means that the max I can get out of my N/A engine is 426 shp. To get more like 500 shp I would have to port the **** out of them, easier to just go aluminum. To figure out how much airflow you need go to this website: http://www.wallaceracing.com/calcafhp.php, the most your going to get out of the 'G's is about 270 cfm, which is enough for 512 crankshaft Hp.
Good Luck
Ray
74sprint is offline
Old February 7th, 2017, 04:17 PM
Stock pistons are deep dish for factory 8.5:1 compression ratio. Prolly gonna be hard to make 500 hp with those.
Fun71 is offline
sammicurr86
September 21st, 2016 10:00 PM
marlar98
May 6th, 2013 03:12 PM
Wildcard
January 2nd, 2013 08:21 AM
HoldSteady
October 3rd, 2011 06:32 PM
tim72
July 19th, 2009 09:11 PM
Quick Reply: The new guy wanting 500hp
