Header choice - '70 442 - hooker super comp 1 3/4 ?
As you know I am working away to get our 442 a little faster! Per my previous post and your advice - headers are next.
I am thinking hooker super comp with 1 3/4 primary's, PN 3101. Long term I plan for good aluminum heads and hydraulic roller cam. 500hp range appears possible based on what I have read.
Again in need of your experienced advice.
What is/are the preferred header choice(s) for the 442? Our car is an factory AC/ TH400 trans car.
In the past (on Chevy projects) I always preferred hooker super comps. I see also hooker has a comp version (PN3902) - those are not typically made as well. ARH and Dick Miller have stainless versions but a bit expensive.
Your thoughts?
Thanks.....James
Your thoughts?
Thanks.....James
If I remember correctly, the larger 1-7/8" Hooker SuperComps, in addition to having larger diameter primary tubes which don't shroud the exhaust ports the way the 1-3/4" do, also have longer primary tubes -- something which is always good for low-end torque. Let's face it, you probably won't be spinning your engine above 5500 RPM, right?
You could actually get by with 1 3/4 if your build will stay mild. Made 500 on those just a few weeks ago.
I wouldn't go more than 1 7/8. I went to 2.00" on a 600+hp build and lost midrange torque. Didn't gain anything up top either.
Thanks for your quick and helpful replies- I was thinking 500hp is likely the transition point for 1-3/4 vs 1-7/8.
James
There you go, go with an expert's opinion. I would have thought 1 3/4" headers were on the small side for 500 HP, the dyno shows otherwise.
You really think that the header size was the root cause for the loss at mid range and top was the headers being to big?
Okay i checked your thread on header test. You tested without the cones and merge collectors which i think means a open tube.That in it's self could account for the loss. Not quite sure why someone would order the ARH without the cones and merge collectors. This was brought up to me by a engine builder as why american racing headers are a very good header is because of the cones and the merge collectors. The one thing not used in your test on this 600 + hp engine. Also stated on ARH site as a big factor to achieve Max torque.
Okay i checked your thread on header test. You tested without the cones and merge collectors which i think means a open tube. Correct That in it's self could account for the loss. Not quite sure why someone would order the ARH without the cones and merge collectors. They didn't come with any merge collector at all. This was brought up to me by a engine builder as to why american racing headers are a very good header is because of the cones and the merge collectors. Yes the tapered cone is inside the collector. The one thing not used in your test on this 600 + hp engine. Also stated on ARH site as a big factor to achieve Max torque.
Thanks.
Thanks for the reply. According to the ARH Tech i called this morning you must have ordered them without as the norm is they come with cones and merge connectors. I think a mix up happened but who knows. Still a very impressive build. My bet is more torque with the cones and merge collector. Possible that it might change your mind set Mark.
I'm fan of their product but their customer service really sucks.
I'm happy with the results! I probably should have had bought a girdle but we both didn't think it would lay down 622 horsepower! Those heads were awesome! I'm sure with a bit bigger cam, more timing and a steel crank I could get 650 but obviously it would still need a girdle!
OLDScience
March 19th, 2016 05:13 PM
speck1148
February 3rd, 2013 06:00 PM
