Choosing/designing a 350 street cam?
Old August 4th, 2016, 05:29 AM
distributorguy's Avatar
Does anyone here have a solid recommendation for a solid street performance cam for a 350? I'm relatively new to Olds motors, and started working on a cam design last night. The design numbers I'm coming up with aren't even close to the aftermarket cams I'm finding. I'll put a few more evenings into the design, but it looks like I'll end up with a custom grind. I'm using DynoSim5 to repeatedly test alterations in design until I come up with an optimal balance of tq/hp. Numbers are seriously inflated, but I stopped and 350hp/525tq last night which probably equates to a real 300/450. Yes I'm a big fan of torque, and the engine design promotes it. A similar cam in a 350 Chev makes 375/375.
distributorguy is offline
Old August 4th, 2016, 06:28 AM
The guy to talk to here about cams is Mark Remmel (CutlassEFI).
He does sell them, but aside from that, he is very experienced with Olds cams, and is a good guy to throw your ideas at and come up with a plan.
It sounds like you've done your homework and understand what you're talking about - that will lead to the most productive conversation.
MDchanic is offline
Old August 5th, 2016, 08:55 AM
marcar1993's Avatar
Agreed, talk to Mark Remmel, I bought my cam from him, and I am VERY happy with it, everything from performance (no track times yet) to idle sound/quality.
The simulators are nice, but there is something to be said for real world experience, its amazing how little things that pop up in the actual application can change their behavior.
marcar1993 is offline
Old August 5th, 2016, 09:18 AM
I've got a couple other cams under my belt like a roller lifter cam in an MGB (never been done before) and a Datsun L20b truck cam to run Bonneville. I also just chose a SBC cam this way, since one on the market was a very close match, and it produced the power numbers I expected. A couple more nights of optimization and I'll have this design ready. I will make a point of running the numbers past Mark when they are done. He'll probably wonder what the hell I was thinking. Truth is, my numbers won't really be done until I see head flow numbers. For now all I can do is use the numbers Dr. Olds' kid has listed for his aftermarket heads, and I have to assume his flowbench is calibrated to a set of calibration plates.
Old August 5th, 2016, 03:55 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Your factory heads flow around 180 intake /145 exhaust, I believe. I have Mark doing a custom cam for me. I want good manners and 13's from my 350. My #6 heads have 2"/1.625" valves with bowl and port work, dual springs and 9.5 to 1 compression, should not be far off stock Procomps. A pair of Procomp heads milled down to 70 CC from Bernard Mondello would be a nice upgrade. Too bad Procomp or Edelbrock don't offer 2 chamber sizes, one in 67 CC would be awesome for 350's and 403's.
olds 307 and 403 is offline
DYSKIE
January 24th, 2015 07:14 AM
HitTheHole
February 1st, 2014 12:04 PM
olds67
June 6th, 2010 09:23 AM
1FSTLS1
December 20th, 2008 05:45 AM
70cutty
August 13th, 2008 05:48 AM
Quick Reply: Choosing/designing a 350 street cam?
