Anybody using PRW 0230201 Stainless Rockers?
I won't be buying HS rockers regardless of the recommendations but thanks anyway. Anyone tried these out?
Do the heads need to be machined or modified in anyway?
Thanks in advance.
Randy
Thanks in advance.
Randy
I'm using he comp cams guide plates and around studs. Used the smaller diameter stud. No issues here. Did not machine the pads for the studs so I had to use slightly longer pushrods. Pattern was damn near perfect.
Thanks Copper, I'm assuming you used the stock diameter studs as they're designed for. Appreciate the input. I'm going to order them.
Red350DropTop
October 19th, 2015 08:27 AM
ToronadoGuyDenver
November 20th, 2007 07:09 AM
