Type O gears
Old June 23rd, 2015, 06:18 AM
Doomah's Avatar
Type O gears
Looking for a set of 3.73 gears for my rear end, I have a 1970 type O POSI rear with 3.23 gear in it and a 671 carrier, I would need the carrier and gears for 3.73.
Thank You
Doomah is offline
Old June 23rd, 2015, 06:47 AM
oldsmobiledave's Avatar
Fyi
Thank You
No such animal. Choose 3.42 or 3.91 as those are your choices. Used or NOS as no one is making new ones.
oldsmobiledave is offline
Old June 23rd, 2015, 07:08 AM
Doomah's Avatar
I thought if I change the carrier in the unit i would be able to get 3.73 or will no other carrier fit in my rear end?
Doomah is offline
Old June 23rd, 2015, 11:18 AM
Magna86's Avatar
With a 71 and up fear you can get that ratio. O type you get 2.56, 2.78, 3.08, 3.23, 3.42, 3.91, 4.33, 4.66, and rare 5.00. The aftermarket carrier used in our rear still only use the O type gears. Want 3.73 find a 71 and up corporate rear core and get it rebuilt. Parts are cheaper generally than O type.
Magna86 is offline
Old June 24th, 2015, 08:24 AM
orange442's Avatar
Richmond gears makes 3.42 and 3.90 gears that are a direct fit for your current posi unit. There has never been a 3.73 gear made to fit the O type 12 bolt. If you are set on getting 3.73 gear, get an 8.5 10 bolt out of a 71-72 Cutlass or Skylark and then you can buy just about anything to build it as there are many different posi units and lockers for 8.5's as well as many manufacturers that make gears for it.
orange442 is offline
Old June 24th, 2015, 08:55 AM
Doomah's Avatar
Thank you for the replys
Doomah is offline
Old July 1st, 2015, 10:01 PM
67442nut's Avatar
3.73 gears are only in the 12-bolt Chevy rear ends like come in the Canadian built Oldmobiles.
67442nut is offline
boc23
Drivetrain/Differentials
August 29th, 2014 02:23 PM
monzaz
August 7th, 2014 11:12 AM
L77F85
16
November 29th, 2013 06:19 AM
chevelless
July 3rd, 2011 03:18 PM
monzaz
May 29th, 2010 08:46 PM
Quick Reply: Type O gears
