398704
Old December 13th, 2014, 04:16 AM
ericsolds's Avatar
398704
Looking for 398704 RH Exhaust Manifold that uses a doughnut gasket in the rear exit or help with the year of this application. ericsolds@sbcglobal.net
or 440-665-5083cell I tried to attach a picture of the manifold I am looking for, Eric
ericsolds is offline
Old December 13th, 2014, 06:02 AM
ROCKETMAN269V's Avatar
398704
This is from the 442.COM parts id section:
YEAR.......ID/.....CASTING.....APPLICATIONS
USED.....CODE...NUMBER
'66...........4.......398704.......RH; 330. Standard issue manifold.
'68 - '73....5.......398704.......RH; X-over. 350. Delta 88.
I should have either one. What year are you in need of? Thanks, Bob.
ROCKETMAN269V is offline
Old December 13th, 2014, 07:18 AM
Paladin31's Avatar
Exhausted
Hey Eric put me 2nd in line after Bob.
1966 #4 casting 398704 with 348 date code
Brett
Paladin31 is offline
Old December 13th, 2014, 08:04 AM
Octania's Avatar
Yet another FAQ-SNAFU from copy-paste-forget to change the #
your casting # is a #4 manifold.
417754 is the casting # of a #5 casting with a straight-down exit. The FAQ should be changed to say that.
Your 45 degree down and back exit can be either a #4 or #3 casting. The donut type (I think) were used on the small block big cars- so, Delta 88's, Jetstar 88, etc.
Octania is offline
Old December 13th, 2014, 08:53 AM
Paladin31's Avatar
Donut
Hey Chris, so does the outlet chamfer vary from 'donut' to non type? And what are the visual que's
Thanks Brett
Old December 13th, 2014, 07:31 PM
ericsolds's Avatar
If anyone has the manifold for sale that is pictured, can they send me a picture of the one they have or post a picture of the entire manifold here. ericsolds@sbcglobal.net
Old December 13th, 2014, 07:40 PM
Octania's Avatar
Thanks Brett
Yes, I believe so. I have seen both types, not sure if the donut type was always BB or always Big Car or what. Visual indicators... of what? Donut use?
The non-donut type has a tapered outlet on the manifold. The donut type has a squared off shoulder end with a nicely machined circular recess into which the donut fits.
Pretty sure you "can" use either type
1) common no-donut manifold or
2) donut type with a donut, which forms the tapered mate to the pipe's tapered flange.
Octania is offline
Old December 16th, 2014, 05:37 PM
Paladin31's Avatar
398704 Manifold
Sorry for delay in responding Eric. Let me know if you need any further pics or info
Brett
Old December 16th, 2014, 07:01 PM
ericsolds's Avatar
398704 manifold that uses doughnut gasket
I know that this part number is used on more than 1 style of this manifold. Please see the picture that I posted on ClassicOlds. I have attached it. I need the style that is machined at the rear for a doughnut gasket to be installed. I will attach a better close-up Eric
Old December 16th, 2014, 08:57 PM
Paladin31's Avatar
Good luck with your search Eric
Brett
Old December 17th, 2014, 02:36 AM
The Rocket Astronomer
lunaboy's Avatar
I have one from a 66 330 jetstar. will get pics to u soon.
lunaboy is offline
Old December 17th, 2014, 03:39 PM
lunaboy's Avatar
sorry what i have is not what you want , someone put a big block 68 T 398708 RH; big block manifold on.
lunaboy is offline
Old December 17th, 2014, 04:19 PM
Octania's Avatar
eric, is there some reason you cannot just use the more common manifold with the taper cast in?
Octania is offline
Old December 19th, 2014, 08:12 PM
ericsolds's Avatar
398704
I feel I have a slight leak at the connection. I think the pipe will conform to a doughnut gasket much better and completely seal. The exhaust shops are using flanges cut out of flat plate steel and you can not put the smoke behind them to seal like the old stamped style flanges.
Old December 20th, 2014, 06:45 AM
Would you like an oem flange? I have some. Thanks, Bob.
Old December 20th, 2014, 05:58 PM
Octania's Avatar
that seems li good solution, factory parts.
Here is a photo of the two type oultets from the Canadian Mother Loade
Octania is offline
Del70
August 11th, 2013 08:54 AM
Quick Reply: 398704
