Under hood insulation pad fasteners 68 Cutlass
Old July 25th, 2016, 07:51 AM
distributorguy's Avatar
Are the OEM clips available somewhere for the underhood sound deadener somewhere? The square plastic ones with 4 round holes and a slot in the middle. I can only find round replacements. '68 Cutlass.
distributorguy is offline
Old July 25th, 2016, 07:56 AM
I moved your post to parts wanted. These parts are plentiful used and would assume someone on here can help your out.
oldcutlass is offline
Old July 26th, 2016, 08:38 AM
I'm just looking for a place to buy them. Anyone? Anyone have a handful of non-broken originals they want to sell? Going into a pristine '68 442.
Old July 26th, 2016, 10:43 AM
69442C's Avatar
Fusick Automotive.
http://www.fusickautomotiveproducts....p?number=11129
Brian
69442C is offline
Old July 26th, 2016, 07:38 PM
Thank you, thank you, thank you!
Old August 3rd, 2016, 02:39 PM
Received the fasteners and they are the wrong size. 1.5" instead of 2" and the post is smaller so they'll fall out of the hole. I found bad internet reviews on them too. What a crap replacement part.
Does anyone have a few of these that survived removal?
Old August 3rd, 2016, 03:38 PM
Randy C.
rcorrigan5's Avatar
I used the Fusick fasteners on my '68 and '69, and I found they fell out at first. But then I found I wasn't pushing them in far enough. After a good push into the existing holes I finally got them to lock in, I haven't had any problems since.
Randy C.
rcorrigan5 is offline
Old August 4th, 2016, 07:25 AM
Unfortunately, this is for a 100% original '69 442. They're visibly not the right size. If need be, I'll try to get the ones out of my convertible to install in the 442, but I'd rather not open that can of worms.
Old August 6th, 2016, 08:42 AM
Paladin31's Avatar
Underhood pad clips
Like these? I may some more, let me know if this the correct items though
Brett
File Type: jpeg
Paladin31 is offline
Old August 6th, 2016, 10:19 AM
Yes those are the ones!!! I need about half a set.
Old August 6th, 2016, 01:26 PM
Randy C.
rcorrigan5's Avatar
I'm trying to figure out the difference between what Fusick has (had?) and the pic posted by Paladin31. The ones I got from Fusick about a year ago are 2" (just went out to the shop to measure and be sure), just like Paladin31's pic. The center is slightly different and I don't know about the length of the post.
Randy C.
Old August 7th, 2016, 06:29 AM
Paladin31's Avatar
'Guy how many do you need & if you could provide a shipping zipcode I will provide a cost, if your interested of course.
Brett
Old August 7th, 2016, 12:20 PM
Crap I got my facts backward. Apparently the Fusick ones are 2", the originals are 1.5".
Old August 7th, 2016, 12:34 PM
Paladin31's Avatar
Underhood
Well the ones I pictured are originals that I removed from my 69 in 1979-80, and are 2" as shown.
Brett
Old August 8th, 2016, 04:26 AM
There must be someone here who can verify the original size? My father-in-law's '68 and '69 both have 1 1/2" clips and both have been in the family since 1 year old. I personally don't know what's correct, just trying to help.
Old August 8th, 2016, 07:51 AM
Randy C.
rcorrigan5's Avatar
The original fasteners on my '68 4-4-2 convertible (Lansing car first week of April '68 build) and my '69 4-4-2 convertible (Fremont car 3rd week of May '69 build) were both 2" square-shaped. I replaced both the padding and the fasteners with parts from Fusick when I restored these cars. The '68 is a nuts-and-bolts restoration - I made sure every original fastener that I had went back into its original place - it was a real **** experience! I haven't been so fussy with the '69 - I'm just not up to doing that again!
Randy C.
Old August 8th, 2016, 10:26 AM
Our '69 442 has only been repainted once, never restored (doesn't need it), and the insulation under the hood is original, with 1 1/2" clips. The '68 442 was the same, but mice ate part of the liner, so it is being replaced. The clips were also 1 1/2".
My '68 has 2" clips, and they appear original, so I just don't know what to say. Not my cars to make the decision on.
jdana24
December 14th, 2014 02:22 PM
jerseyjoe
September 2nd, 2013 02:45 PM
70Post
August 28th, 2012 10:36 AM
Gearhead442
Body work
June 5th, 2012 08:10 PM
spider
August 27th, 2011 07:30 AM
Quick Reply: Under hood insulation pad fasteners 68 Cutlass
