442 Positive battery cable junction block.
Old September 14th, 2014, 11:24 AM
oldspackrat's Avatar
I removed this from a '65 Delta 88. Not sure if it's correct for other years/models, check before purchasing.
There is one small crack on one side but otherwise it is nice & will clean up easily.
I'd like to get $30.00 for it shipped.
Scott
c. 317-727-7041
oldspackrat is offline
Old September 14th, 2014, 03:48 PM
jag1886's Avatar
Does it work?
jag1886 is offline
Old September 14th, 2014, 04:03 PM
I'm not familiar with how these things work. I just saw this on a car I knew that some people were looking for them. Can you give me a quick explanation?
Old September 14th, 2014, 04:44 PM
nicks1966's Avatar
that is also the horn relay, if the coil inside the cover is no good, no horns
nicks1966 is offline
Old September 16th, 2014, 07:10 PM
Majored in rear tire demo
2Olds4U's Avatar
Scott, do you still have this?
2Olds4U is offline
Old September 16th, 2014, 08:19 PM
Paul,
You are 2nd in line if the first guys changes his mind.
Old September 18th, 2014, 12:43 AM
nsnarsk65cutlass's Avatar
That's the horn relay,they rust out and don't work,if it's cracked?ohm check it.
nsnarsk65cutlass is offline
Old September 18th, 2014, 03:48 AM
Thanks, it does work & it is sold.
pogo69
June 6th, 2015 04:40 PM
dephconn24
April 27th, 2012 05:04 PM
matviar
April 2nd, 2012 05:18 PM
joepenoso
October 16th, 2011 11:46 AM
supersport
January 15th, 2009 09:43 PM
Quick Reply: 442 Positive battery cable junction block.
