Turbo 400 Manual Shift Valve Body with Transmission Brake
Old May 15th, 2013, 01:23 PM
Ron McHugh's Avatar
This is an older style internal trans brake for a Turbo 400. The valve body is for the reverse pattern gear selection and will not upshift manually-no modulator. Please be aware of what this is before you decide you want to consider. It appears to have originally been made by Select Performance, but when ATI was converting my trans from manual reverse pattern and removed this, they noted that it is the same as theirs along with the Coan unit. The only difference is that this valve body incorporates the solenoid from the 3-2 'kick-down' as the release button. The unit was tested by a racing trans shop in Penna by bolting it into a Turbo 400 case and testing the solenoid plunger travel depth. It works just fine, however, there are quicker releasing solenoids being marketed. $200 or best offer Ron 703 509 0762
Ron McHugh is offline
ATrain1
November 26th, 2012 07:02 AM
80_cutlass
March 17th, 2011 06:03 PM
Liegekiller
15
June 27th, 2009 07:58 PM
Liegekiller
May 30th, 2009 05:31 PM
Quick Reply: Turbo 400 Manual Shift Valve Body with Transmission Brake
