| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
HELP please! Blown Engine
Long story short. I have a blown Buick 455 that was in my Delta 88 and a Olds 455 that I just bought to replace. I had planned to swap parts to get the Olds running, but that was before I realized I had a Buick engine in my car. From what I understand practically nothing is interchangeable. My question is can anyone recommend where and what basic parts to get this OLDs 455 running again? I have searched extensively only to find performance parts that will not fit my budget. The Olds 455 is the block, head, intake, pistons, crankshaft etc.) just looks like all the components were stripped off (distributor, starter, carburetor). Is the flywheel, starter, anything from the Buick usable?
| Sponsored Links |
#2 (permalink) |
Junior Member
HELP Blown 455s!
Long story short. I have a blown Buick 455 that was in my Delta 88 and a Olds 455 short block that I just bought to replace. I had planned to swap parts to get the Olds running, but that was before I realized I had a Buick 455 in my car. From what I understand practically nothing is interchangeable. My question is can anyone recommend where and what basic parts to get this OLDs 455 running again? I have searched extensively only to find performance parts that will not fit my budget. The Olds 455 is the block, head, intake, pistons, crankshaft etc. It just looks like all the components were stripped off (distributor, starter, carburetor). Is the flywheel, starter, anything from the Buick usable?
#3 (permalink) | |
Senior Member
Quote:
I guess if the block will fit in the car, the rest comes with it, it will work. You didn't say anything about the transmission. One good thing about GM, it is still GM. Last edited by kevinkpk : 11-26-2007 at 02:22 PM. |
#4 (permalink) |
You will need to get Olds specific brackets, water pump, distributor, intake, carb, exhaust manifolds, flywheel, hoses, cables, perhaps power steering pump (not sure), and probably some other things I forgot or missed. Not an easy task but possible. If you transmission is a TH400 then you should not have trouble bolting it to the Olds block but you may need a different flywheel as I mentioned. Good luck, that is a big project.
__________________
Dan '77 Cutlass Supreme '46 2 door |
#5 (permalink) |
Seasoned beater pilot.
-Wouldn't the frame mounts be entirely different?
-What year is this Delta? You will probably have to find another Delta88, or similar B-body from the same year, and use the Oldsmobile frame mounts instead of the Buick ones. From what Joe P. told me... as far as an Olds350 / buick 350 swap, the motor and frame mounts will NOT interchange. I don't know about a 455 buick, but I'm assuming it is a similar scenario. I can get away with using mounts from a 3.8 cutlass for my buick 350, but you will probably have a harder time with a big block. Also, pay attention to what side the trans cooler lines/fuel pump/lines etc are on. It might just be easier for you to replace it with another buick motor.
__________________
#6 (permalink) |
I don't think anything will interchange.
__________________
#7 (permalink) |
Alero Chapter Secretary
Summit racing and Jegs are a great place to find a lot of the stuff. Mondello Twister is expensive, but they do have the cranks for 455s and a complete gasket kit.
It will be a lot of work and money, but yes the parts are out there I find Summit and Mondello's web sites the easiet to go though ![]() www.summitracing.com www.jegs.com www.mondellotwister.com www.dickmillerracing.com |
#8 (permalink) |
The only common parts are the distributor cap and rotor. Sorry.
__________________
Joe Padavano 64 Jetstar 88 Conv 66 442 L-69 Conv 68 W-30 69 H/O 69 442 70 W-30 72 442 84 Custom Cruiser 86 Caprice wagon (w/307 Olds) |
#9 (permalink) |
Also, if you are anywhere near chicago, I know of 3 buick 455's for sale in the area.
__________________
#10 (permalink) |
Landyacht Club President
You can use the carburetor. It is probably just a Quadrjet.
#11 (permalink) |
Sounds like you have basically a short block. Don't know what your budget would be but this won't be cheap, won't even be reasonable. Unless you are a die-hard Olds enthusiast, then the price of resurrecting an Olds Big Block is worth every penny!
Threads have been merged....
__________________
Dan '77 Cutlass Supreme '46 2 door Last edited by Oldsguy : 11-27-2007 at 05:01 AM. |
#12 (permalink) |
Junior Member
Thank you
I am truly overwhelmed by the responses. I definately have alot of work in front of me. Since I have a Oldsmobile I am going to try to rebuild the OLDS 455 to put in it. My car is a 1973 Delta 88. I can't tell that any modifications were done to put the Buick 455 in the car? Hopefully I won't have too much trouble putting the Olds 455 in it since that is what it was originally. I belive the transmission is a TH400. It i basically a short block so if i just can find all the componrnts to add on it shouldn't be too bad$$ right? I built a "garage" out of a free wood fence to cover the car and now my journey is really just getting going. My wife is laughing but she can't wait to ride again!
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| how do you clean an engine and engine compartment? | pinky | Eighty-Eight | 6 | 10-01-2007 11:24 AM |
| engine & engine compartment colors | Olds luvr | Small Blocks | 0 | 01-07-2007 11:42 AM |
| Blown head gasket? Way too hot!!! NEED HELP!! | elisowski | Big Blocks | 4 | 09-15-2003 07:46 PM |
