2 1970 350 engine transmission cores
first one is a 1970 short block with a bad rod bearing on #2. somebody put 8 heads on it. it ran when i pulled it but knocked pretty bad. i was told it had a nut dropped in the intake and bent a valve but that turned out to not be true. comes with 8 heads, exhaust manifolds, HEI, alternator and power steering pump and brackets. no A/C brackets included. cylinders look good but it is sitting outside covered so it will go down hill fast. i was told the TH350 transmission worked but i never tested it. was told that by the same guy that said about the bent valve. i just want it out of the way but don't want to ship it. will take $75 for it.
second engine is a complete 1970 2bbl engine. it ran when i pulled it but sit outside for several years. it will turn a little but not a complete revolution. still has the #6 heads. no A/C brackets but the alternator and power steering pump and brackets are there. HEI distributor. the transmission is bad and out of a 70 Vista Cruiser so it is the long tail shaft. $150
100_4785.jpg?t=1319845820
100_4787.jpg?t=1319845848
100_4797.jpg?t=1319845888
jstrits
November 13th, 2014 07:42 AM
