Go Back   ClassicOldsmobile.com > Oldsmobile Classifieds > Parts For Sale
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 09-24-2007, 06:07 AM   #1 (permalink)
monzaz
Senior Member
12 bolt Olds 442 rear 3.91 TO code rear anti spin /posi/ Limited slip
I have a great 3.91 anti spin Olds 12 bolt Original TO code 1968 442 rear differential forsale. Thought I would give you fir dibs before it gets Ebayed.
The whole rear has be gone through and checked out. This was removed from a customers GTO...??? How it got in there who knows. It is in excellent condition. Axles bearings checked and new seals installed. Posi unit and gears were removed and all checked out. Posi was reconditioned. then everything was reassemble back to factory specs with .008 backlash and is ready for MUSCLE CAR WORK.
This rear would be great for the factory Nostalic racing where original parts must be used. An excellet ratio for drag racing or proweling around town...
looking for 900.00 I am sure it will bring more on ebay.
specs
ring gear tooth count 43
pinion tooth count 11
588 carrier
1968 rear
Pictures can be sent as long as you pm me with your email address. Ok?
Mega Brake kit can be added for 185.00 that will make this rear a complete bolt in ready to go unit and includes: NEW drums, shoes, wheel cylinders, hardware kit, hardlines bent like factory, and rubber chassis brake hose. That is all assembled adjusted and ready to bleed and go...
Take care and if you need any help on differential stuff please give a shout...here to help. Jim
monzaz is offline   Reply With Quote
Sponsored Links
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
12 Bolt "O" axle rear $300 dan1s Parts For Sale 2 03-16-2008 11:13 AM
1970 olds 98 455 rear end posi troy1 Ninety-Eight 4 02-12-2008 01:49 PM
1968 442 3.90 posi 12 bolt olds rear for sale monzaz Parts Wanted 0 09-11-2007 07:06 PM
12 bolt Olds rare 31spline anti spin (posi unit) 672 case monzaz Parts For Sale 0 09-04-2007 10:50 PM
rear diffriintal convertion to posi diablo76delta88 Small Blocks 0 05-24-2004 04:47 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
