2 more rebuilt 8.5" 10-bolt posi rears,3:23 & 3:42
I have 2 more 8.5" 10-bolt posi rears that will soon be finished.I am doing one with 3:23's,and the other with 3:42's.The housings are hot-tanked,blasted,primed,and painted,Eaton posi,Motive gears,Timken bearings & seals.Filled with fluid & additive,and ready to run.Backing plates included,but no brake hardware. $975.00 plus the freight.
These came from 71-72 Cutlass/442's,but will fit any 64-72 GM A-body.These are a direct bolt-in,meaning that ALL of the mounting points are the same.For those of you with 64-65 Cutlass/442,this rear is 5/8" wider on each side,so check to make sure you have room to move your wheel outboard 5/8",or if you are in the process of getting new wheels,you can order the rear wheels with 1/2" deeper backspace,to keep the wheel centered inside the wheel house.
If you are swapping from an 8.2" 10-bolt,to this 8.5" 10-bolt,your driveshaft will need to be shortened about 3/4" due the the pinion snout on the 8.5 being longer,so you need less shaft to reach it.Any other questions,just ask.
Interested in the 323 if the deal falls through, if not 3:42 is just fine. Shipping to 97045? Can email me at comstockbrian@msn.com. Thanks!
Brian,
It came with 3:23 gears...but I didn't know the code was SS. I understand yours it complete with gears, clutches, posi unit, case, housing, etc, everything except for brakes right? All cleaned up and painted? How much $...and how much to ship to Texas? FYI, you sold me a tranny and a distributor before and I was very satisfied, so I know your stuff is top-notch. Michael
81 regency
April 21st, 2011 06:18 PM
507OLDS
December 4th, 2009 04:34 AM
