10 bolt 8.5 ring and pinion 3.73 3.42 gear sets original used gm
10 bolt cover - 10 bolt ring corporate GM 8.5 1970-2016 ring and pinions.
1971 1972 Cutlass or 1973-1977 cutlass 1984-1987 442
Hope this helps.
12 bolt olds will ALWAYS have 27 spline pinion the corporate GM 8.5 will always have 30 spline pinion.
>>>>>>>>>>>>>> NOT FOR 12 BOLT OLDSMOBILE 8.5 GEARS <<<<<<<<<<<<<<<<<<
2 sets of GM ORIGINAL USED 3.73 10 bolt 8.5 75.00 each SOLD
1 set of GM ORIGINAL USED 3.42 10 bolt 8.5 85.00
shipping is 13.85 a set
thank you, Jim
Akron, oh
pm for more info.
Hope this helps.
thank you, Jim
Akron, oh
pm for more info.
Thank you....Im aware of that. The question was posed to coax more info out of monzaz.
[/QUOTE]If these were O-Type gears I think he would have specifically said that.[/QUOTE]
Why is that? Respectfully, there is at least two Olds rear ends that Im aware of that had 342:1, 10 bolt, 8.5" ring geared rear axle assemblies. The 67 thru early 70 A body "Type Os" and late 70-72 A body "GM Corporates". Which are they?
The 373:1s are likely out of an 85-87, 442...also an 8.5", 10 bolt. monzaz is an Olds guy so Ill assume its not another brands 373:1 gear set?
It wouldn't matter if the 8.5" 3.73 gear set was out of an '85-'87 442 or a Chevy truck; they would be the same thing and fit the same applications: any GM 8.5" 10 bolt corporate rear.
12 bolt olds- get use to calling the rear that. 8.5 is just the ring gear diameter...
dana 44 is 8.5
gm has 12 bolt olds 8.5
10 bolt corp 8.5
Only gears available for the Olds 12 bolt are 3.42 and 3.90 aftermarket Richmond gear.
3.73 was never an available 12 bolt olds gear.
Sorry Jim
The 373:1s are likely out of an 85-87, 442...also an 8.5", 10 bolt. monzaz is an Olds guy so Ill assume its not another brands 373:1 gear set?[/QUOTE]
That is absolutely correct... I always reference 'O' type as 12 bolt OLDS I never reference the ring gear size because it really measures 8.4 ...which I wish they would have done from day one. Jim
Oh and if you look at the picture you can see that they are not 12 bolt olds gears. The shafts look totally different as they use totally different crush sleeves. (example pictured)
Info is up that should clear the whole ad.
Just a little info. The O Type 12 bolt was first used in 66.
Last run at these gears
We just got one more set of 3.73 gears and a set of 3.08 both VG used GM ORIGINAL GEARS FOR the corporate 8.5 10 bolt from 1971- 2018
2 sets of 3.42 are here also.
Thank you, Jim
Thank you, Jim
monzaz
October 15th, 2016 08:23 AM
