Dissasemble the engine without tranny, question
Old April 27th, 2015, 02:24 PM
Oldsragger's Avatar
Wondering how you guys do when you take out the engine when let the tranny stay in car, do you disasemble the engine Mount from block to get it easyer out from the tranny house, or loosen the motormount bracket from frame, or motormount from bracket only?
To me it looks like a problem if only i should loosen the motor Mount from brackets, cause i guess the engine have to go a little forwards before its outside the tranny house and can lift the engine up?
I have dissasemble all bolts now but not the motormount bolts cause i want to hear what you recomand.
Another thing, should i find a block to have under the tranny Pan so it will not fall down when engine goes out?
B body olds btw
Thanks.
Oldsragger is offline
Old April 27th, 2015, 03:31 PM
TripDeuces's Avatar
There is a bolt between the engine mount and the frame mount. Undo that bolt and nut and remove it on both sides.
Have the transmission and converter unbolted from the engine and put a jack under the pan. Preferably on a block of wood to spread the load across the pan. You can loosen the transmission cross member to transmission mount bolts but don't remove them yet.
Start lifting the engine and once it clears the frame mounts you can slide it forward freeing it from the transmission. Be sure to jack the transmission up as you go. It's only about and inch or so up that you have to go. Don't let the converter fall out.
TripDeuces is offline
Old April 27th, 2015, 10:19 PM
Oldsragger's Avatar
Ok thanks i will try that, i didnt tought i have to loose the trasmission from the crossmember, but maybe it makes easyer to lift the engine out of the enginebrackets.
Old April 28th, 2015, 06:28 AM
TripDeuces's Avatar
I only loosen them so that you can raise the trans enough so that the engine will clear the frame mounts. Don't want to rip the trans mount. No need to stress it if you don't have to.
Old April 28th, 2015, 06:41 AM
Oldsragger's Avatar
I see, ok thanks i will try that. Need to cut down a tree first to have under the Oil Pan.
Old May 7th, 2015, 09:43 AM
Oldsragger's Avatar
Its very hard to Split the engine from the tranny house, all the bolts are out, tip what to do now?
Old May 7th, 2015, 09:46 AM
The torque convertor needs to be unbolted and stay with the trans. The engine an trans needs to come up about 2 inches to clear the motor mount, then us a pry bar in between the block and tran to separate.
oldcutlass is offline
Old May 7th, 2015, 10:13 AM
Oldsragger's Avatar
Problem solved, just needed to get up a small flat skrewdriver to Split it in the corner of tranny, so now its fine, yeah converter bolts was out too.
Old May 7th, 2015, 10:19 AM
Oldsragger's Avatar
Isnt this a dual bolt pattern tranny for chebby and for sure b.o.p? all i know it have a smc before long time ago, but they Keep the tranny maybe when sbo swap again.
RXN
September 20th, 2014 05:04 AM
joepenoso
January 31st, 2013 09:50 PM
Oldsbiel
March 26th, 2011 09:43 AM
import extermination
May 17th, 2009 11:07 AM
ToronadoGuyDenver
Brakes/Hydraulic Systems
March 18th, 2007 02:52 AM
Quick Reply: Dissasemble the engine without tranny, question
