ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Other
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Dealer Listings
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old November 9th, 2005, 05:57 PM   #1 (permalink)
DonFrost
Member
Exclamation
Can I remove this junk from my car and at the same time hollow out the catylitic converter? Do I just plug the holes in the manifold with some bolts and weld the spots on my exaust where the AIR feeds to the cat? Anyone who has done this all and knows what is going on with it all please help!
__________________
81 Ninety-Eight Regency 307 CA car Clean never seen salt and I'm in MN. (nuttin Special) Just in love with my Oldsmobiles. Had a 79 with the 350, liked that better.
DonFrost is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old November 10th, 2005, 12:32 AM   #2 (permalink)
jdorour
Senior Member
Post
Don,
You can remove the AIR and the cat from the car with no problem as long as your car is not OBD2.
As you did not say what year car or what engine I will give you generic info. If you live in an area that requires visual inspection you will not pass the SMOG test. If you live in an area that requires only a test You have a 50/50 shot at passing. That said...
You can remove the pump and tubes from the engine. you can get brass 3/8 (If I remember right) NPT plugs to plug the holes in the manifolds. You can gut the CAT. The beed type used by GM in the 70's and early 80's can be a pain but all you have to do is take it off cut the baffel out of each end and dump it out. The later honeycomb type can be broken up with a pry bar or something like that.
Keeping in mind that a good high flow cat will not hurt performance. I would replace the OEM CAT with a good modern high flow design. The air pump takes less horsepower to run than the alt takes. There is really no need to pull it off. The equipment is not crap. It was installed for a reason - to reduce the emmissions.
__________________
1966 Ninety Eight Convertible - 425 Tri-Carb, Factory Dual Exh, Switch-Pitch THM400, 3.54 Posi.
1966 Catalina Wagon - 421 Tri-Power, M21, 4.11 Saf-T-Trac, 8 Bolt Wheels
1989 IROC-Z - 5.7TPI
jdorour is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
spin on oil filter adaptor 1955' 88 GTC Eighty-Eight 6 February 7th, 2008 02:18 PM
Rare Nostalgia Part?-8 Pack manifiold for B/B Olds - Can anyone identify it ? V8Hotrod.com Big Blocks 11 May 24th, 2007 06:59 PM
1955 olds super deluxe autoradio American Lead Electrical 3 January 5th, 2007 02:40 PM
Please post your location 2blu442 Parts Wanted 0 December 10th, 2006 10:51 PM
1966 Olds 3-2bl. Set Up 30MOD A Big Blocks 0 November 6th, 2006 04:36 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
