ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Other
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old February 21st, 2008, 05:32 PM   #1 (permalink)
Pfiffle
Sea foam
Anyone use it? Or is it just another gimmick "fix all".
Pfiffle is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old February 21st, 2008, 05:33 PM   #2 (permalink)
J-(Chicago)
Seasoned beater pilot.
J-(Chicago)'s Avatar
I think it sucks.
__________________
I'd rather have a numbers matching poker hand.
J-(Chicago) is offline   Reply With Quote
Old February 21st, 2008, 06:18 PM   #3 (permalink)
J-(Chicago)
Your best bet is to run a top tier gasoline if you want a cleaner engine. Chevron, Shell, or 76 are all good gasolines.
http://toptiergas.com/deposit_control.html
Seafoam is just Alcohol, water, naptha
and refinery runoff pale oil. http://lyondell.com/lyondell/techlit...0_PALE_OIL.pdf
Also I suggest that you do some research on hydrolock before you use it. Even though it will be very hard to hydrolock anything with a small can of seafoam, it's a good thing to know about before putting random liquids into your motor.
__________________
Old February 21st, 2008, 06:50 PM   #4 (permalink)
Pfiffle
Ok, I'm glad I asked. I've got a dieseling problem with my 1970 Ninety Eight 455 4 barrel. I bought it off a 90 year old woman and I'll bet she was using the cheapest gas available and probably lower octane that this engine requires. I believe It has 10.25:1 compression. I'll start with draining the tank and filling it with Super, give it a good run, and see what happens. Thanks.
Old February 21st, 2008, 07:01 PM   #5 (permalink)
J-(Chicago)
Check your timing.
__________________
Old February 22nd, 2008, 12:09 PM   #6 (permalink)
Pfiffle
Yes, I will check the timing. Thanks. It's on jack stands for now but when I let it down, I'm going to install the Pertonex coil/ignition in it also. Carb probably needs a rebuild after 38 years too. I'm going to stay away from Sea foam.
Old February 22nd, 2008, 12:37 PM   #7 (permalink)
The_Jeremiah
what i always do, is fill it with premuim and add some fuel injector/carb cleaner, and take it down the freeway at 75. for awhile good luck
__________________
69' Cutlass 4 door. Built 455 inside, grandma's grocery getter outside. Best sleeper in disguise.
The_Jeremiah is offline   Reply With Quote
Old February 22nd, 2008, 01:42 PM   #8 (permalink)
Pfiffle
Wink
Yes. I will give it a good run.
Old February 22nd, 2008, 03:50 PM   #9 (permalink)
Olds64
Landyacht Club President
I like Sea Foam. I think it is one of the better oil/gas additives. They might not do much but they can give you peace of mind.
Oldsguy had a 1989 Ford LTD with a 5.0L engine that had sticky lifters and leaky valve guides. A friend of his had some auto tech students take a look at it. They drained the oil, filled it with Sea Foam and let it sit for a week. Then they drained the Sea Foam, added oil and an appropriate amount of Sea Foam to the crankcase and started it up. No more noisy lifters. However, the additive must have destroyed the valve guide seals because it smoked HORRIBLY!
__________________
Ferris, my father loves this car more than life itself... Apparently, you don't understand! Ferris, he never drives it! He just rubs it with a diaper!
Cameron Frye Ferris Bueller's Day Off 1986
Olds64 is offline   Reply With Quote
Old February 22nd, 2008, 04:25 PM   #10 (permalink)
don71
feed the pig
don71's Avatar
I have had good luck with sea foam. Following the directions on the can, it cured my problem. I make it a habit to use it twice a year now.
__________________
1971 Cutlass S Holiday coupe-455/th400 3.23
Oldsmobile they were meant to be driven.
don71 is offline   Reply With Quote
Old February 23rd, 2008, 08:36 AM   #11 (permalink)
J-(Chicago)
If they had filled Oldsguy's motor with trans fluid, it would have probably worked with a similar (or better) result.
__________________
Old February 23rd, 2008, 08:50 AM   #12 (permalink)
Oldsguy
Hot Rodder at heart Administrator
Oldsguy's Avatar
Quote:
Originally Posted by Olds64 View Post
....Oldsguy had a 1989 Ford LTD with a 5.0L engine that had sticky lifters and leaky valve guides.....:
I was sure relieved to sell that thing. It had just gotten old, and since it was not an Oldsmobile, no need to save it.
__________________
Dan
'77 Cutlass Supreme
'46 2 door
"The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB.
Oldsguy is offline   Reply With Quote
Old February 23rd, 2008, 09:08 AM   #13 (permalink)
Pfiffle
Well, then I guess it's an option if Good gas and ignition/timing don't solve it. As I said, the previous owner was a 90 year old woman who used it to go to Bingo and the food store so It probably didn't see the highway much. It's got 76,000 original miles and it's a Texas car. The paint is fried but there's no rust. Still waiting for my QQ plates though (New Jersey!) and theres alot of snow and salt on the roads here. A good highway run might help. Thanks for all the input.
Old February 23rd, 2008, 09:28 AM   #14 (permalink)
Bluevista
Cruisin' the Vistas
Bluevista's Avatar
Does that carb have the anti-dieseling/stall dashpot or solenoid? I had the same problem when I shut mine down and just adjusted the solenoid/dashpot to specified rpm and the reset the timing to specs, always with premium gas and to running temperature. If it is doing it while driving timing and bad gas would be suspect as mentioned in the other posts. The Pertronix unit is a good move, first thing I do is put pointless conversions in my cars. I have had good luck with the Mallory Unilite conversion unit, have had one for 12 years in my Goat and has never missed a beat. I remember all the boat guys using that Sea-Foam stuff when I was a kid, my Dad swore by it. I always find tons of sludge in the engines of old folks cars, a lot just don't drive far enough to warm them up properly.
Allan
Bluevista is offline   Reply With Quote
Old February 23rd, 2008, 09:50 AM   #15 (permalink)
Pfiffle
Where on the carb would that dashpot be located? I know theres a dashpot on there but I'm not sure if it's the one you are reffering to. Tom.
Old February 23rd, 2008, 05:52 PM   #16 (permalink)
rocketraider
Oldsdruid
Look on the driver's side front of the carb. Sometimes they're electric, sometimes vacuum operated, and sometimes just a simple spring dashpot. The idea is to drop idle speed/throttle plate opening to where the engine starves for air and can't run.
You must remember 1970 was the peak of Olds high-compression. Those engines do not like low octane gas; they were designed for 100-106 octane. Use the best premium you can find and add some lead substitute to each tankful. Jack Podell www.jackpodellfuelinjections.com sells a good quality product that is about the only one I've found that does what it claims.
SeaFoam won't hurt a thing in your engine. Like Marvel Mystery Oil, a product doesn't stay around for 60+ years unless it does something right. Used properly it's a very good decarbonizer/top engine cleaner.
Trans fluid, MMO or Rislone are high detergent fine oils that, used in the crankcase, will dissolve sludge and free sticky rings and lifters. However, they don't do anything for carbon buildup on valves and pistons. You need a different type of solvent for that. Diesel and JP-4 are some powerful solvents if you're not afraid to put a quart or so in your tank when you fill up, but the car will smoke and stink like nothing you ever saw...
J, I'm not following your hydrolock theory. You put the SF in thru a vacuum port, it's going to vaporize before it hits the intake valves. A liquid goes from atmospheric pressure to 15-20" Hg vacuum, it's not going to stay liquid. That's why it's possible to pour some water down the carb throat and crack off carbon deposits. It vaporizes under engine vacuum, and when it hits combustion chamber temps, it flashes to steam.
__________________
I know absolutely nothing about Oldsmobiles.
Just ask the owner of Oldspower.com
rocketraider is offline   Reply With Quote
Old February 23rd, 2008, 07:06 PM   #17 (permalink)
GoodOldsGuy
GoodOldsGuy's Avatar
Quote:
One other forum member mentioned a decarbonizer...I think you might have carbon buildup on top of the pistons. With the engine hot and the compression ratio as high as it is, the run on might just be caused by the glowing carbon on top of the pistons. Just MHO. A little water or Top Engine Cleaner (GM) drizzled in at RPM (2,000) then let stand for 20 min. Start up and stand back. (smoke) When it clears your problem should be gone. Just my 2 cents. Hope this works for your problem.
Regards,
GoodOldsGuy
GoodOldsGuy is offline   Reply With Quote
Old February 23rd, 2008, 10:24 PM   #18 (permalink)
J-(Chicago)
Quote:
Hey man, I have seen hillbillies take off their carbs, and dump the bottle down their intake before. You just never know what people are going to do with it.
Oh you broke your leg?? rub some Robitussin on it, let it soak in. Haha. You never know.....
__________________
Old February 24th, 2008, 06:07 AM   #19 (permalink)
Pfiffle
Excellent info Guys, thanks. This site never lets me down.
Old February 24th, 2008, 07:51 AM   #20 (permalink)
Olds64
I have also heard that you can pour ATF down the carburetor while the engine is running to help clean the engine. I don't know if it works but it surely makes the engine smoke. I could definitely see how Sea Foam, Diesel, or JP4 would clean the engine when used in the same manner. I would just be afraid of damaging something.
__________________
Old February 24th, 2008, 11:05 AM   #21 (permalink)
Pfiffle
Yes, thats my concern. I really don't know much about the history of this car axcept that an older person owned it.From that I'm just guessing that the cylinders have some carbon in them and thats whats causing the dieseling and read somewhere that Sea Foam clears that sort of thing. I know in the old Days my father used to take his cars on a (High Speed) highway run to "blow the carbon out" once in a while. Speeding tickets and insurance were cheaper back then though.
Old February 29th, 2008, 02:00 PM   #22 (permalink)
Pfiffle
Well, I sea foamed it.(1970 Ninety Eight) Had it sipping through the PCV hose from a cup. Turned it off. Waited 5 minutes. Started it up and no thick cloud of smoke. It didn't diesel when I turned it off though. Should I have used another vaccum hose? Or did it do It's job? I was expecting a big cloud and I did it today because It's cold as hell outside and my nieghbors would not get that shit in their houses with windows closed. The gas gauge worked for a while too ( I recently drained the old gas with a siphon) maybe that loosened the mechanichels in the sending unit. Any thought? Tom.
Old February 29th, 2008, 02:27 PM   #23 (permalink)
Oldsguy
Oldsguy's Avatar
If that is the way the directions said to apply it then you did it right. No cloud of smoke? Does it warn you that will happen? Perhaps expecting to break down the valve guide sludge? I don't know.....
Maybe adding some to the fuel tank would loosen some more stuff but then you run the risk of clogging the filter sock on the fuel pick-up in the tank, or worse, if the sock is gone/deteroirated taking that gunk up to the fuel pump or the carburetor.
__________________
Dan
'77 Cutlass Supreme
'46 2 door
Old February 29th, 2008, 02:47 PM   #24 (permalink)
Pfiffle
Oh Boy! Didn't think that the sock may be gone. Good thought. Better drop the tank, you think?
Old March 1st, 2008, 09:24 AM   #25 (permalink)
88 coupe
Junior Member
88 coupe's Avatar
Quote:
Originally Posted by J-(Chicago) View Post
Your best bet is to run a top tier gasoline if you want a cleaner engine ........
Or you can do a couple of, zero to the speed limit, on ramp entrances at WOT.
........ Chevron, Shell, or 76 are all good gasolines ........
From elsewhere, on the same site: http://toptiergas.com/retailers.html
Quote:
TOP TIER Gasoline Retailers:
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
MFA Oil Company
Kwik Trip/Kwik Star
The Somerset Refinery, Inc.
Chevron-Canada
Aloha Petroleum
Tri-Par Oil Company
Shell-Canada
Texaco
Petro-Canada
Sunoco-Canada
From: http://www.usatoday.com/money/indust...terstitialskip
Quote:
All gasoline should be adequate. The U.S. Environmental Protection Agency requires a certain level of engine-cleaning additives in gasoline. And bulk gasoline before the additives go in must meet certain industry standards. But Shell and others trying to distinguish themselves from the discounters say that fuel meeting just those minimum standards won't keep your engine clean.
The "placebo" effect applies.
Norm
__________________
Quote:
Originally Posted by 380 Racer View Post
Quote:
Originally Posted by 88 coupe View Post
None of us can know what we haven't learned yet .....
........ I saw Norm's "helpful" answer and encouragement as a slam ........
88 coupe is offline   Reply With Quote
Old March 1st, 2008, 10:02 AM   #26 (permalink)
88 coupe
Junior Member
88 coupe's Avatar
Quote:
Originally Posted by don71 View Post
........ Following the directions on the can, it cured my problem ........
What problem?
If they had filled Oldsguy's motor with ........
Or simply changed the oil and filter.
Quote:
Originally Posted by amh555 View Post
........ Pertronix unit is a good move ,.......
Only from a maintenance standpoint.
........ all the boat guys using that Sea-Foam stuff ........
I understand it's a good "fuel stabilizer" for the off season.
Norm
__________________
Old March 1st, 2008, 01:57 PM   #27 (permalink)
Pfiffle
OK, thanks for all the help everyone.
Old July 12th, 2009, 09:05 AM   #28 (permalink)
Joeypete
Joeypete's Avatar
Send a message via Yahoo to Joeypete
I've used it a few times and it seems to work pretty well. Both engines ran better. It IS supposed to produce white smoke after you let it sit for a few minutes. Depending on the build up, you may smoke a lot, or a little. Both cars I used it on had carbs and I just slowly poured it down the throat (while revving the engine slightly)...then you dump a good amount down so that it stalls...let it sit for say 10-15 minutes and start it up.
__________________
1986 Custom Cruiser
2009 Ford Focus SE Coupe
Joeypete is offline   Reply With Quote
Old July 12th, 2009, 12:29 PM   #29 (permalink)
My442
The best stuff to pour down the carb is GM Top Engine Cleaner.
Techron works best in the gas.
My442 is offline   Reply With Quote
Old July 12th, 2009, 10:49 PM   #30 (permalink)
Joeypete
Joeypete's Avatar
Cool, I didn't realize that GM still made that stuff...good to know!
__________________
1986 Custom Cruiser
Old August 13th, 2009, 08:38 PM   #31 (permalink)
slumpy
ive used sea foam quite a bit, but never really saw a difference either way with or without it, i just like using the stuff, makes me think im doing some preventitive maintinance or something, but i do know the stuff is getting expensive.
slumpy is offline   Reply With Quote
Old September 12th, 2009, 02:44 PM   #32 (permalink)
mugzilla
is Fast Enough ...
mugzilla's Avatar
blow compressed are back up the fuel line ...
After you do this check your fuel filter a couple three times and look for particulate ...
mugzilla is offline   Reply With Quote
Old September 12th, 2009, 02:45 PM   #33 (permalink)
mugzilla
is Fast Enough ...
mugzilla's Avatar
Oh yeh ...
I like water for cylinder decarb ...
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
