| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Senior Member
can you fast forward an odometer?
since im going to be rebuilding my motor and trans and doing the differential soon after i was wondering if i could fast forward the odometer to zero without damaging the unit
i've heard of people trying to rewind the odometers and damaging something insdie which stopped its operation but i have never heard of anyone fast forwarding them and i was wondering if any of you guys new anything about this
__________________
![]() my cutlass as of 08/27/2007 |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) | ||
Junior Member
Quote:
Quote:
I know it's illegal to turn it back. One legal way, would be to purchase a new odometer unit from your GM dealer. Just be careful to reposition all the numbers, so they show the actual mileage, before you lock them into position. The above procedures would also apply, when replacing the one you already have, if you happened to remove it for any reason. Norm |
#3 (permalink) |
Landyacht Club President
It depends on your state's laws regarding mileage on an older vehicle. I know in MO vehicles are exempt from odometer readings during safety inspections after a certain year. When my car was registered in MO the mileage section of the title said "exempt."
If you want the odometer to read "00000.0" then you can always purchase an aftermarket speedo / odometer. I would think you would pay an arm and a leg for a GM unit. Plus, I doubt you could even purchase one from your GM dealer (since it is so old). ![]()
__________________
Ferris, my father loves this car more than life itself... Apparently, you don't understand! Ferris, he never drives it! He just rubs it with a diaper! Cameron Frye Ferris Bueller's Day Off 1986 |
#4 (permalink) |
Dont know about Calif.Like 64 said about MO. Its your car take it apart & re set it where you want it.carefully one # at a time so you keep the even.Learned this after using a air powered speedo cable lube gun .forgot to use regulator & trashed a customers speedo ! Had to get a used one & re set it. They are not hard to do just delicate.
#5 (permalink) | ||||
Junior Member
OK. I will play your silly game.
Do you know what your state's laws actually say? Quote:
Quote:
Quote:
Quote:
Norm |
#6 (permalink) |
Junior Member
#7 (permalink) |
Senior Member
im not to worried if its illegal or not the state of california only cares if you keep track of the actual mileage if you ever sell the car so somewhere in my notes i would record what it was at right now then clock it back to 0
but i was only wondering if it was possible to reset them and what is involved in doing it
__________________
#8 (permalink) | |||
Junior Member
Quote:
Quote:
Quote:
Norm |
#9 (permalink) | |||||
Quote:
![]() Quote:
![]() Quote:
![]() Quote:
![]() Quote:
__________________
#10 (permalink) |
Super Moderator
I'll wade into this thread. First, it is VERY easy to disassemble the speedo and manually reset the odometer drum. I've done it on several of my Oldsmobiles when I've rebuilt them. There is a very thin plastic shim between each of the individual sections of the odo drum. This shim is what breaks if you incorrectly force the drum to reset. If you do it carefully by disassembling the speedo, there's no problem.
Second, let's get serious here. There is absolutely no difference between resetting the odo to zero and installing a new one. For that matter, you can also install a whole new speedo with a different odometer reading. ALL of these are perfectly legal, since repair of the odometer is allowed by law. As with VIN tampering, the federal laws only address odometer tampering WITH INTENT TO COMMIT FRAUD. The VIN tag issue should be the topic of a different thread, however. State laws do vary. Here in Virginia, you must note odometer inaccuracies in the appropriate space on the title. Do that and it's perfectly legal.
__________________
Joe Padavano 64 Jetstar 88 Conv 66 442 L-69 Conv 68 W-30 69 H/O 69 442 70 W-30 72 442 84 Custom Cruiser 86 Caprice wagon (w/307 Olds) |
#11 (permalink) |
Senior Member
yeah that same law you have in virgina on odometers and noting the actual mileage applies to california aswell joe
__________________
#12 (permalink) |
Junior Member
Isn't that what I said in my first post?
#13 (permalink) |
LOL, I hope your questions were answered
__________________
69' Cutlass 4 door. Built 455 inside, grandma's grocery getter outside. Best sleeper in disguise.
#14 (permalink) | |
Super Moderator
Actually, not exactly. You said this:
Quote:
And not that I necessarily pay much attention to Click and Clack but ironically the covered exactly this topic in their column on Sunday - with the same answer.
__________________
#15 (permalink) | |||
Junior Member
Quote:
I also said: Quote:
Quote:
Shak: Start at the highest number and work down. Should take you less than 20 seconds. Norm |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| fast shifting | GOLD72OLDS | General Discussion | 5 | October 31st, 2007 06:34 PM |
| 76 Olds - Need Carpet Fast. | Devon76 | Cutlass | 3 | May 25th, 2007 01:29 AM |
| Please help...advice needed Fast | Want-A-Vert | 442 | 13 | December 20th, 2006 08:06 PM |
| cutlass doesnt go fast | 2 door cut | Cutlass | 0 | September 5th, 2006 07:29 PM |
| odometer | tpkj | Other | 0 | March 11th, 2005 05:46 PM |
