| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Guest
Posts: n/a
I have a 1985 cutless cierra 2.5l and recently I have developed a couple of problems. Most recently it has developed a problem while driving down the road. I go about 4 or 5 miles and it just stalls out as if it's out of gas. I replaced the fuel pump and filter but it still does same thing. If I pour gas into carb. it starts up again and will drive for a few miles and does it again. This car has what looks like a fuel injector system attached to a carborator if that makes sense.
The other problem I have is the car will not pass smog. It was way over in the last catagory of test. I don't have the paperwork in front of me here at the moment. I know this is pretty vague for info but if anyone ideas, info or related stuff to help I would appreciate it. thanks |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
2Blue 55
It sounds like your carb is not adjudted right, the fuel air mixture was bad on mine as i am restoring a 55' , also on on the side there was a large plastic screw to set thr richness on it. I heard the engine improving as soon as i adjusted it, another idea is to google carb troubleshooting and see what popsup, this is what i did with mine, good luck,
ps, you made need a carb kit, as there are many variables |
#3 (permalink) |
You inclued one Clue * Emissions test! Is your catalic converter pluged up ? This is Quite common on those with 80000+ miles+, When it starts this hold a rag over exhaust check flow .The converter can be gutted out (For test purpose Only) .Then replace for proper sensor operation .
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Anyone intrested in a 94 Camaro??? $1575.00 | tex70 | Cars For Sale | 1 | January 27th, 2007 09:31 PM |
| 68 Cutlass wont start | 68oldsrocket | Cutlass | 24 | December 19th, 2006 08:20 PM |
| 39 degree 425 Engine | rt38 classic engines | Big Blocks | 3 | May 9th, 2006 06:28 PM |
| another olds guy | odin3eye | Cutlass | 4 | March 30th, 2006 10:00 PM |
