New fuel lines
Old October 22nd, 2011, 08:31 AM
bobfo1's Avatar
New fuel lines
I've got new fuel lines and fuel line clips to put in a 66 442. Does anyone have experience putting the clips in (red color...same as original). The centern of the clip is a rivet, and I'm not sure how to install it in the hole drilled in the frame. Also, any suggestiions on how to get the fuel lines in? Probably a lot easier with a frame off!
bobfo1 is offline
Old October 23rd, 2011, 06:28 AM
Jay D's Avatar
My installation was a frame off so I had a lot of access to get the fuel lines in. The hardest part was running the two lines through the front frame horns. Just take your time and don't force the lines. You can run some wire through the frame and then fish the hard lines through. As for the clips, I tried to just tap them into the frame holes but they didn't hold. To remedy this I installed them in the frame holes and then took a taped punch and opened the rivet by tapping the punch. All of the clips held without any problems.
Good luck.
Jay
Jay D is offline
Old October 24th, 2011, 06:08 AM
bobfo1's Avatar
Fuel lines
Tha.nks Jay
It looks like the fuel lines should be routed so that the small line (return) is on the bottom. Is that correct? My 66 has a jury rigged set up for the lines so I can't tell how it is supposed to be
bobfo1 is offline
Old October 24th, 2011, 06:41 AM
Jay D's Avatar
My Detroit Iron assembly manual shows the main fuel line on the bottom. I guess you could run it either way though.
Jay D is offline
Old July 11th, 2016, 01:51 PM
seanm12's Avatar
Red Fuel line clips - How to attach to the frame?
I hope someone sees this by looking under New Posts. I just got the new red clips for the fuel lines. They are the rivet style. I'm not sure what Jay D means by using a "taped punch". Is this a tapered punch, starts thin and gets wider? Simply pounding something like that inside gets the "rivet" to expand and hold on to the frame?
Apologies if I'm asking something obvious.
Sean
seanm12 is offline
Old July 11th, 2016, 04:10 PM
Jay D's Avatar
Fuel Lines
Sean,
Sorry about the typo. That should have said "tapered punch". After installing the clips I used the tapered punch to open the rivet a little more and this helped holding the clips in the frame.
I did this quite a while ago so I had to go back over the original posts. Hope this helps.
Jay
Jay D is offline
Old July 30th, 2016, 08:46 PM
seanm12's Avatar
Jay D - Thanks for that clarification.
seanm12 is offline
507OLDS
March 29th, 2014 12:08 PM
gearhead1218
August 10th, 2010 08:18 PM
69Rman
February 26th, 2010 05:10 AM
oldzy
January 29th, 2010 06:06 PM
Charlie_brown
September 29th, 2009 04:01 PM
Quick Reply: New fuel lines
