Go Back   ClassicOldsmobile.com > Repair & Restoration > Other
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 09-21-2007, 02:14 PM   #1 (permalink)
mcutlass1969
Member
Question Missing Radiater Flued
Just rebuilt a 455 and got a couple hundred miles on the motor. I put an edelbrock package on it so I have the aluminum heads and intake. Now after driving it for a little while I have to add about a quart of fluid to the radiator after a 30 minute drive. I have an overflow but the fluid never pulls from the reservoir. I have a pretty heavy hose on the overflow as well as I have blown air through the line and reservoir. This leads me to were else the fluid could be going. I keep an eye on the fluids on the car and the radiator fluid is clear and clean. The oil is also clear. I have also parked the car and kept an eye on the ground with no luck. Any suggestions?
Another note: with the aluminum intake I received 2 slugs that are to be put in when the intake doesn't match up with the holes on the block. These were not put in due to all ports matched up.
mcutlass1969 is offline   Reply With Quote
Sponsored Links
To remove this ad, register today!
Old 09-21-2007, 02:23 PM   #2 (permalink)
joe_padavano
If you're sure the coolant isn't leaking out a crack or loose hose or bad cap, then it's going into the engine. Could be bad intake gasket, bad head gasket, or a crack that only opens up when the engine is hot.
The two plugs are not for "mismatched" ports. They are to block the heat riser under the carb if you choose to do so.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is online now   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Missing cowl tag robs442w30 442 2 09-15-2007 12:11 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
