ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Other
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Dealer Listings
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old April 5th, 2004, 01:06 PM   #1 (permalink)
Dan
Junior Member
Post
Hello All
I recently placed a topic in the small block section. I haven't received a reply so I figured I'd try again. I have a couple questions maybe somebody out there can help me with. First of all is there any headers available for the small block '67 cutlass? I only found companies that go back to '68.(I looked at the car and it looks awfully tight) If there are not headers available then I've heard you have to "cap" one of the outlets on the passenger side to have dual exhaust.(any info?) Another question is I have a '67 cutlass parts car with side marker lamps. They look original but I have never seen them on this year of car. Any info is appreciated. Thanks......
Dan is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old September 2nd, 2005, 04:05 PM   #2 (permalink)
Dave Ramos
Junior Member
Post
I have a 1966 Cutlass with your 330 small block. I also have some headers for a 1967 400 motor off a 442. I am going to try to make a muffler shop put them on anyway they can. Bang, Cut, weld! anyway I will let you know what I encounter, the headers were cheap, I can't see paying 600.00 for the "Krooks" Version small block headers when all the exhaust gaskets were the same for all oldsmobiles and the small block is smaller than the big block so why wont they fit.There ought to be more room in there for these headers. I don't understand so I will try it to see.
[ September 02, 2005: Message edited by: Dave Ramos ]</p>
Dave Ramos is offline   Reply With Quote
Old September 3rd, 2005, 11:26 AM   #3 (permalink)
jdorour
Senior Member
Post
Hi Dan and Dave,
The headers from the 400 should fit the small block. The bolt pattern is the same for the big block and small block. The port size is smaller on the small block head. If you install big block manifolds or headers on a small block use bigblock gaskets. If you use small block gaskets with the big block headers the gasket will be exposed on one side of the port and will burn. The BBO is two inches wider and about 1 inche taller than the SBO. The BBO header will fit.
I have to add that I have never had good luck with headers on Oldsmobile engines. The bolt pattern does not apply an even clamping force on the gasket and you will fight leaks all the time. If you get a set of headers make sure the flange is nice and thick. The flanges need to be dead flat.
__________________
1966 Ninety Eight Convertible - 425 Tri-Carb, Factory Dual Exh, Switch-Pitch THM400, 3.54 Posi.
1966 Catalina Wagon - 421 Tri-Power, M21, 4.11 Saf-T-Trac, 8 Bolt Wheels
1989 IROC-Z - 5.7TPI
jdorour is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
1971 cutless supreme convertible tony73mach1 Cars For Sale 4 June 8th, 2007 10:44 PM
Shifts hard Arctic Bravada Transmission 3 February 9th, 2007 07:08 AM
wont come out of park Tod Cutlass 3 January 25th, 2007 06:27 AM
engine rebuild ct1979 Small Blocks 2 January 22nd, 2007 09:55 PM
75 olds conv. shaunr Eighty-Eight 0 November 18th, 2006 05:47 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
