Vacuum diaphragm for air cleaner
Old January 9th, 2017, 05:38 PM
Nihayde's Avatar
Evening folks
On my 70 442 I had to replace my vacuum diaphragm as it would not actuate with a vacuum. The one that came with my car had a bend in the metal stick that presses on the valve in the air cleaner to allow hot air into the engine.
On the new one the metal stick is straight. I noticed on the valve in the air cleaner there is a hole that allows the metal stick to fit into it if I bend the stick.
My question what is the proper setup? I consulted my engine and assembly manuals and see no reference to how to setup.
Thanks in advance.
Nihayde is offline
Old January 9th, 2017, 06:36 PM
2blu442's Avatar
Just to clarify, this is the valve in the snorkel of the air cleaner housing correct? John
2blu442 is offline
Old January 9th, 2017, 06:38 PM
Nihayde's Avatar
Yes it is
Nihayde is offline
Old January 9th, 2017, 07:01 PM
2blu442's Avatar
OK, if someone doesn't post the answer first I'll dig around the garage to see if I can find a stock one to verify it should have the bend in it.
2blu442 is offline
Old January 10th, 2017, 09:34 AM
Nihayde's Avatar
Thank you
Nihayde is offline
Old January 10th, 2017, 08:22 PM
Randy C.
rcorrigan5's Avatar
I had to replace the one in my '69 4-4-2 and the replacement piece came without the bend. I had to put the bend in it myself, which I did with a couple pair of vice grips. It turned out surprisingly well and the new assembly fit together nicely.
Randy C.
rcorrigan5 is offline
Old January 11th, 2017, 04:54 AM
Nihayde's Avatar
Thank you much.
Randy C.
Nihayde is offline
My2nd 69 442
August 17th, 2016 06:15 PM
4Ceesuns
June 6th, 2014 02:54 AM
MN71W30
March 9th, 2013 02:37 PM
wmlewis
March 15th, 2012 10:21 PM
Steve Wike
October 26th, 2010 06:35 AM
Quick Reply: Vacuum diaphragm for air cleaner
