How do you test a speedometer?
Old November 13th, 2016, 04:20 PM
50 Olds FAN
Jim Kniola's Avatar
I have a non-working speedo in my '50 Olds 88 dash. The cable is not broken as proven by chucking it in my drill and working it both clockwise and counter clockwise. I can't tell if the problem is the gear in the transmission or the mechanism of the speedometer. How can I test the speedometer?
Jim Kniola is offline
Old November 13th, 2016, 05:25 PM
lemoldsnut's Avatar
Hook the cable up to the speedo and the drill and try it.
lemoldsnut is offline
Old November 13th, 2016, 05:54 PM
Sometimes there is a bit of a collar protruding from the back of the speedo, and you can just put that right in the drill chuck.
That being said, usually if you whing it around really fast with your fingers, the needle will jump a bit.
MDchanic is offline
Old November 13th, 2016, 07:12 PM
50 Olds FAN
Jim Kniola's Avatar
Did that as my first step. When I did this, I heard some activity behind the – by the speedometer that I don't usually hear when I'm going down the road. So the speedometer didn't work but at least it was making some noise. This makes me think that maybe I have a two headed snake: the transmission gear and the speedometer. Does that sound right to you?
Old November 13th, 2016, 07:13 PM
50 Olds FAN
Jim Kniola's Avatar
First of all, I love your pink convertible! Concerning the speedometer, I would have to take it out of the dash in order to do that, right? I'm prepared to do that but as long as I have it out, if it doesn't work where would I take it or who would I send it to?
Old November 13th, 2016, 08:18 PM
steverw's Avatar
Redline Gauge in Humbolt Tennessee
steverw is offline
Old November 14th, 2016, 04:30 AM
Thanks!
... I would have to take it out of the dash in order to do that, right?
If you can reach the end and get the spinning part between your fingers, you might be able to spin it in place.
If you do that, though, and the result isn't clearly good, then I agree that it will have to come out.
MDchanic is offline
shamusj
March 4th, 2016 06:48 AM
jmills
November 8th, 2014 07:30 AM
MASH4077
February 22nd, 2011 11:07 AM
Danny Boy
Suspension & Handling
March 31st, 2010 01:53 AM
IB Adrian
September 12th, 2009 12:43 PM
Quick Reply: How do you test a speedometer?
